Looking for place to buy ARP studs/bolts....
Topic: Looking for place to buy ARP studs/bolts.... (Read 3861 times)
January 05, 2007, 09:14:13 pm
Barry W
January 05, 2007, 09:14:13 pm »
Looking for a company that stocks the ARP bolts or equivalent. I am rebuilding a 1.6L turbo and looking for cylinder head bolts, and possibly con rod bolts.
Also need to know if the 1.8 8V gas stud kits are the same as the 1.6 turbo diesel?
Thanks!
January 05, 2007, 09:32:21 pm
January 05, 2007, 09:32:21 pm »
http://www.raceware-fasteners.com/index.htm
January 05, 2007, 10:39:49 pm
Barry W
January 05, 2007, 10:39:49 pm »
That looks promising. Thanks!
January 05, 2007, 11:27:49 pm
hillfolk'r
January 05, 2007, 11:27:49 pm »
all the older 8v's should use the same studs(gas or diesel),as long as they are both 12mm to begin with
Throttle cables ftw
January 06, 2007, 12:38:47 am
Audi80
January 06, 2007, 12:38:47 am »
I bought my studs from
Summit
Gas engines use 11mm bolts, those won´t fit.
January 06, 2007, 12:48:42 am
Barry W
January 06, 2007, 12:48:42 am »
what other stretch bolts need replacing on a rebuild?
January 06, 2007, 12:52:42 am
vwmike
Authorized Vendor
January 06, 2007, 12:52:42 am »
The rod bolts and the head bolts are your biggest concerns.
January 06, 2007, 01:39:21 pm
Barry W
January 06, 2007, 01:39:21 pm »
Thanks.
January 09, 2007, 01:03:00 am
DA-BRT
January 09, 2007, 01:03:00 am »
Are these ARP bolts also Strech bolts? Or can I re use them?
Does anybody knows whichs Rod bolt set I have to get from ARP? It's for a 1.9TD (AAZ) engineblock.
Greetz.
Bert
-=<To>=-
For sale:
M-TDI pumps 12mm (Prepared for VAG TDI engines)
January 09, 2007, 01:58:15 am
Audi80
January 09, 2007, 01:58:15 am »
You can reuse them.
January 09, 2007, 02:27:41 am
DA-BRT
January 09, 2007, 02:27:41 am »
That's better!
Greetz.
Bert
-=<To>=-
For sale:
Reply #11
January 10, 2007, 12:09:31 am
studs
Reply #11 on:
January 10, 2007, 12:09:31 am »
I bought my studs from Summit Gas engines use 11mm bolts, those won´t fit.
Will the 11mm gasser studs fit the 11mm early NA diesel block with the 11mm headbolts.
I've seen the 11mm blocks with 12point, triplesquare, 11mm, gasser streeatch bolts... so I figure the studs will work.
If so it would be a nice upgrade for the weaker 11mm diesel headbolts that are too short and put large stress on a small area.
