Author Topic: 1.6 gtd rebuild  (Read 3304 times)
January 02, 2007, 02:01:44 pm
Hillshy
  • 103
    • http://www.hillshy.co.uk
1.6 gtd rebuild
« on: January 02, 2007, 02:01:44 pm »
the first sight of the inside of my 1.6td lump.
all 4 cylinders have cracks in between the valves.
http://images.kodakgallery.eu.com/photos211/1/24/17/49/19/5/519491724133_0_ALB.jpg
has anyone had these welded up, i would imagine lots of work involved here.
hillshy
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #1January 03, 2007, 10:40:07 am
bert
  • 423
1.6 gtd rebuild
« Reply #1 on: January 03, 2007, 10:40:07 am »
Halesowen engines had my 1.6 in for rebuild at 1100 quid,thats why i scrapped it and went 1.9,my 1.6 head was a 1986 C reg golf and when i say the head was cracked,it was frightening how wide and deep the cracks were,the surfaces of the head were no longer flush with each other and it ran perfect,just too much blowby so i took the head off to look  :cry:  bores were well worn,over top measured limit,I asked about a new head and they said no,its fine,the cracks are normal on every vw diesel they do,they said a new head will crack in 6-12 months so leave alone.
Bert
Reply #2January 03, 2007, 12:48:51 pm
SMOKEYDUB
  • 630
1.6 gtd rebuild
« Reply #2 on: January 03, 2007, 12:48:51 pm »
the cracks are very normal
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #3January 03, 2007, 07:34:51 pm
1.6 gtd rebuild
« Reply #3 on: January 03, 2007, 07:34:51 pm »
best to just let the cracks be
Reply #4January 03, 2007, 09:09:40 pm
myke_w
  • 1099
1.6 gtd rebuild
« Reply #4 on: January 03, 2007, 09:09:40 pm »
If you are reallly worried about this, have the head pressure tested at a shop before you reinstall.. Likely, if it wasnt loosing coolant, and you weren't seeing air in the coolant bottle, you're sitting pretty.
