Author Topic: IP Bearing tolerance  (Read 2437 times)
January 09, 2007, 02:01:23 am
kuggkrans
  • 8
« on: January 09, 2007, 02:01:23 am »
Does anybody know what tolerance the bearing have on the input shaft?
I have measured hte shaft to 16,9975 mm
and the outer bearing to 17,038 mm
and the inner bearing to 17,030 mm
Reply #1January 09, 2007, 06:10:39 am
kuggkrans
  • 8
« Reply #1 on: January 09, 2007, 06:10:39 am »
sorry it should be
I have measured hte shaft to 16,9775 mm
Reply #2January 09, 2007, 07:39:03 pm
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
tolerance for Drive shaft bushings
« Reply #2 on: January 09, 2007, 07:39:03 pm »
hi
the max tolerance for the drive shaft bushings is .15mm as measured
in the side to side where belt pulls.
hope this helps.
we measure it with a special tool and a dial indicator while moving the
shaft back and forth and a handle extension on the DS.
Giles
