View full version: IDI Engine
  1. Smoke at high speed
  2. 1985 1.6 wont start!!!
  3. O-ringed head/block?
  4. Mercedes Nozzles
  5. 1.9 aaz vibration damper.......new and improved?
  6. Glow Plug idiot light blinks
  7. Oil pan removal
  8. What parts to mod a 1.9TD pump?
  9. TDI exhaust on td?
  10. veg oil / waste motor oil percentages .....
  11. The Hybrid Turbo is complete
  12. aaz crank bolt torque
  13. Show your intercooler setups!
  14. Final consensus on timing advance mod ?
  15. Muffler be gone!!
  16. Injection Pump Flush?
  17. need help with 1.6td pump convo
  18. Picking the right trans
  19. Little fuel leaks
  20. How much smoke is ok without an EGT
  21. turbo downpipe
  22. EGT mounting
  23. Compression Test and Headgasket Questions
  24. Banging noise?!
  25. poor idle at start excessive white/grey smoke 85 TurboDiesel
  26. pros and cons on frankenmotors
  27. No Boost
  28. k14 turbo upgrade ?
  29. Coolant sensors diagram??
  30. Possibilty for a 1.5 or 1.6L
  31. 1.9L AAZ fuel milage
  32. 1.6TD performance loss questions
  33. Boost gauge hookup?
  34. Has anyone thought of using....
  35. K24 wastegate problem??
  36. Do I need a BOV?
  37. do oil pumps fail suddenly?
  38. Adjustment from the govenorshaft for properfunction???
  39. where to mount oil pressure sender?
  40. Turboing a 1500 NA
  41. Final drive and gear ratio for 82 diesel westy?
  42. AAZ Turbo Feed Oil line
  43. 1990 IDI OK in Seattle?
  44. Intermediate shaft carnage
  45. Basic MF rebuild cost
  46. Normal running temp for a 1.6 TD?
  47. adding more gauges question
  48. AAZ Power house? Mighty Mouse?
  49. 1.6TD camshaft and pump questions
  50. 1.6 TD fuel filter
