Author Topic: adding more gauges question  (Read 2738 times)
June 28, 2008, 09:53:34 am
silvertdi
  • 125
« on: June 28, 2008, 09:53:34 am »
First, is the + terminal on my 81 rabbit the same as the "W" terminal i've heard people speak about?  Do I hook it directly to a tach?
Second, my oil filter housing isn't threaded and tapped.  Is there an alternate location for another oil sender, other than the head?
Thanks.   :D
Reply #1June 28, 2008, 12:13:26 pm
Re: adding more gauges question
« Reply #1 on: June 28, 2008, 12:13:26 pm »
Quote from: "silvertdi"
Nope.... sadly you need a  real "W" terminal for the tach... the "+" is the output of the alternator.
Nope... most people run a M10x1 tee to add a sensor to the existing port.  Anyone that sells VDO gauges will be able to get you the VDO version... about 7 bucks.
Reply #2June 28, 2008, 08:15:23 pm
silvertdi
  • 125
« Reply #2 on: June 28, 2008, 08:15:23 pm »
Hmm.  There's nothing hooked up to my + terminal.  It's just a spade connector recessed in the alternator case.  There's a plug that pushes into a connector which feeds the car's circuits.  The + terminal on mine is unused and looking lonely.
Reply #3June 28, 2008, 08:45:24 pm
« Reply #3 on: June 28, 2008, 08:45:24 pm »
It's an output that is used, on some cars,  to connect a noise-suppression capacitor... with a spade connector.  If you do a bit of searching here for "tach" you'll see some pictures of alternators with a small black box mounted on the back... that's the noise suppressor that plugs into the "+" spade connection.
Reply #4June 30, 2008, 03:30:48 am
silvertdi
  • 125
« Reply #4 on: June 30, 2008, 03:30:48 am »
I see.  My car has the Motorola alternator, not the Bosch.  I replaced it about 4 months ago.  Neither the old or the new have a "W" terminal.  Is there a year range of rabbit or jetta that had the "W" terminal?  Is it on the Motorolas or the Boschs?  Thanks for all your help.
Reply #5June 30, 2008, 05:18:59 am
« Reply #5 on: June 30, 2008, 05:18:59 am »
If you are willing to take your alternator apart, you can solder a wire between one set of windings and the diode, run it out of the case, and there is your W terminal. Just be sure to insulate it well.
Reply #6June 30, 2008, 07:30:20 pm
Turbinepowered
  • 1206
« Reply #6 on: June 30, 2008, 07:30:20 pm »
Oddly enough, my gasser Fox from '89 has a W terminal on its alternator.
