EGT mounting
Topic: EGT mounting (Read 2114 times)
July 06, 2008, 04:52:15 am
ThomZe
EGT mounting
July 06, 2008, 04:52:15 am »
Hi, was wondering where you guys mount the EGT in the exhaust system? Is there somewhere to "screw it in" or does I have to make a hole myself?
Just want to know before I order one
BMW E36 320i Automatic
July 06, 2008, 05:21:52 am
numbnuts
EGT mounting
July 06, 2008, 05:21:52 am »
I believe some peoploe put it in the turbo downpipe for ease but the best place to put it is in the exhaust manifold, so it will be a drill and tap jobbie. At least that was where i was going to fit mine which i have just ordered
Either that or i will weld on a nut onto the turbo dowpipe right on the bend :wink:
July 06, 2008, 12:41:11 pm
EGT mounting
July 06, 2008, 12:41:11 pm »
This thread:
http://forums.vwvortex.com/zerothread?id=3915057
has a good picture of what most consider to be the optimal spot for mounting the EGT sensor... on a flat spot in the middle of the manifold where it will see the heat from all four cylinders as uniformly as possible.
One thing is sure...because the turbo converts a variable amount of heat into energy mounting the sensor post-turbo (like on the downpipe) renders the gauge practically useless from a diagnostic point of view.
July 07, 2008, 06:28:23 am
saurkraut
EGT mounting
July 07, 2008, 06:28:23 am »
http://vwdiesel.net/phpBB/viewtopic.php?t=4583&postdays=0&postorder=asc&start=30
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
EGT mounting
