Author Topic: Banging noise?!  (Read 3093 times)
July 03, 2008, 05:09:41 pm
rwdriver
  • 107
Banging noise?!
« on: July 03, 2008, 05:09:41 pm »
so I took my 1.6td jetta for a spin yesterday, and at wot, I ran out of fuel. I got some fuel in it, then start it up, and now there's a banging noise coming from the intake. It sounds like an exhaust leak, but it isn't.  It "bangs" once an rpm i think, so I don't think it's the valvetrain. It doesn't get louder when I rev it, it's the loudest at idle.  I really hope I didn't cook my engine. Has this happened to anyone else?  Thanks for the help in advance
Reply #1July 03, 2008, 11:28:56 pm
Banging noise?!
« Reply #1 on: July 03, 2008, 11:28:56 pm »
hmmm... does the engine vibrate bad at idle??? try cracking each injector one at a time to see if rpm's drop.  you'll know when you've found the culprit.
could be many other things too though.
Reply #2July 05, 2008, 06:11:31 am
rwdriver
  • 107
Banging noise?!
« Reply #2 on: July 05, 2008, 06:11:31 am »
I checked the cam timing, and it's dead on. The weird thing is that the car still runs like normal. the engine doesn't really vibrate much at idle.
Reply #3July 05, 2008, 06:13:09 am
rwdriver
  • 107
Banging noise?!
« Reply #3 on: July 05, 2008, 06:13:09 am »
any suggestions?
Reply #4July 05, 2008, 06:34:52 am
burnt_servo
  • 278
Banging noise?!
« Reply #4 on: July 05, 2008, 06:34:52 am »
Quote from: "rwdriver"
any suggestions?
you have a midget with a large hammer living under your hood ......
might be wise to evict him soon :D
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #5July 05, 2008, 07:07:27 am
gigaz2
  • 626
Banging noise?!
« Reply #5 on: July 05, 2008, 07:07:27 am »
hipothetical: an injector dripping, stuck open or not atomising properly.
Reply #6July 05, 2008, 06:54:23 pm
rwdriver
  • 107
Banging noise?!
« Reply #6 on: July 05, 2008, 06:54:23 pm »
that sounds possible, i'll try to find which one is bad
Reply #7July 06, 2008, 02:27:52 am
gigaz2
  • 626
Banging noise?!
« Reply #7 on: July 06, 2008, 02:27:52 am »
damn my brain wasn't functioning properly..  if you ran out of fuel while at WOT, there is good chance there is air somewhere.
Reply #8July 06, 2008, 02:28:02 pm
rwdriver
  • 107
Banging noise?!
« Reply #8 on: July 06, 2008, 02:28:02 pm »
air? like where? it still idles and drives fine
