Author Topic: Injection Pump Flush?  (Read 3241 times)
July 07, 2008, 08:59:40 am
Spokerider
  • 195
« on: July 07, 2008, 08:59:40 am »
The IP that came with my aaz has been removed and sitting in a box along with other engine parts for the last three years. The previous owner did not cover the fittings where the fuel lines connect, or any other ports leading into the pumps internals..........
I'm going to be bolting it back onto the engine soon and am concerned that grunge may have forund it's way into the pump just from sitting in a dusty shop. Anyone "flushed" an injection pump? I'm wondering if injecting clean diesel via a large syringe into the fuel inlet and letting it flush out the 4 holes would be ? a good idea? Maybe blow some compressed air through the fuel inlet to move the old fuel through?
I don't want to tear into this thing  :roll:
Cleaning the outside of the IP? After reading the brake-cleaner thread, I'm thinking of useing a water-based cleaner like Simple Green or other detergent type solvent. Thoughts?
Thanks!
Reply #1July 07, 2008, 09:09:23 am
gigaz2
  • 626
« Reply #1 on: July 07, 2008, 09:09:23 am »
you could run it with no injectors for a while, but a good rebuild would be way better.
Reply #2July 07, 2008, 03:06:50 pm
Fisher
  • 148
« Reply #2 on: July 07, 2008, 03:06:50 pm »
Use ATF to flush it out.
Reply #3July 07, 2008, 05:35:25 pm
« Reply #3 on: July 07, 2008, 05:35:25 pm »
you won't be able to get rust out. If it's been sitting dry there is a good chance it is rusted inside. Look at the ends of the delivery valves, and take out the in and out banjo bolts and have a look in there for signs of rust. You could take off the advance covers and have a look as well. That should give you a pretty good idea.
Reply #4July 07, 2008, 05:41:11 pm
« Reply #4 on: July 07, 2008, 05:41:11 pm »
Quote from: "burn_your_money"
1x.
i wouldn't trust a pump that has been sitting for too long without the holes blocked...  especially being in BC where things rust as fast or even faster than in my garage  :lol:
Reply #5July 07, 2008, 08:19:20 pm
Op-Ivy
  • 513
« Reply #5 on: July 07, 2008, 08:19:20 pm »
Quote from: "jtanguay"
1x.
Agreed. Theres no way to get it cleaned out properly without taking it apart. I would just bite the bullet and at least take a peak inside.
