View full version: IDI Engine
  1. Mk2 Golf
  2. Making this thing quieter.
  3. How do you fit a boost gauge to a 1.6 TD?
  4. suggestions on a good transmision for a mk1 with a 1.6td
  5. Coldness sets in
  6. What size the frost plugs (block plug) in a 91 diesel?
  7. Need help with IP models! Updated with pics!
  8. Check out my new exhaust manifold head flanges
  9. EGT Probe question
  10. Turbo Compounding (Edit: now gone VNT!)
  11. Rabbit 1.6 diesel idling way to fast.
  12. Time to install the Viton!
  13. AAZ engine data.
  14. Rebuilding Alernator
  15. AAZ Combustion chamber part number?
  16. Biodiesel (At the pumps)
  17. Injector pump upgrades - Research and Development work
  18. 14mm injector head
  19. Way to increase spring tension on BOV?
  20. Newbie from the UK
  21. symptoms of a worn injection pump?
  22. Stuck blow off valve????
  23. Getting the most out of my N/A Diesel
  24. Timing belt (again)
  25. What the Hell is this?? For the pump guys. (pics)
  26. another Compression Ratio question
  27. What can I do without an EGT Gauge?
  28. Are there uprated 1.9TD glow plugs?
  29. Where to get LDA and pump rebuild kit??
  30. wierd tach problems
  31. mk1 now Turbo diesel.
  32. I need a clutch.....
  33. Bits on ebay - Are they worth getting for a 1.6td?
  34. Aluminun Radiator
  35. Techtonics Tuning 2.25" DP VS Passenger Performance 2.5
  36. Vanagon/T3 TD Exhaust quandry.
  37. coolant pipe woes
  38. New to the diesel world here.....
  39. Pre-fill fuel filter with 1-K kerosene?
  40. Timing belt
  41. looking for an old post Help
  42. removal of block heater????
  43. 1.7l 16v TDIm?
  44. Cummings 4b pump questions
  45. 1.9 NA on its way, what to do to it?
  46. has anyone really modified a NA diesel?
  47. AAZ exhaust porting
  48. Tell me about injectors.
  49. K24 Drain Line on 1.9 AAZ Problem
  50. Quick AAZ engine question
