Author Topic: coolant pipe woes  (Read 3203 times)
August 19, 2006, 05:32:59 pm
BellCityDubber
  • 251
coolant pipe woes
« on: August 19, 2006, 05:32:59 pm »
Alright,
I went from having a botched starter, and began replacing it, when I sprung a leak in the coolant pipe
(the one from the heater core hose to the middle waterpump hose, it has 2 nipples/flanges on it. One for the coolant tank, and one for the oil cooler)
Does anyone have any tips or anything on how to replace this pipe? I've got everything disconnected and unbolted, but I cant manage to get it out... I think I might have to pull the oil filter to get it out, and maybe the coolant pipe to the head and a few sensors....
has anyone replaced this pipe before??
Reply #1August 19, 2006, 06:17:02 pm
rabbid79
  • 684
coolant pipe woes
« Reply #1 on: August 19, 2006, 06:17:02 pm »
This is the rigid metal pipe that runs from the side of the engine over to the back right?  I'm not sure the best way to get it out with the oil filter flange on.  I recently did mine, but most of the stuff like the oil filter flange, etc., was already removed from the engine.  I don't know what year your car is, but for my '79 diesel, it was NLA.  I was able to get the pipe from a '78.  The only significant difference was there was an extra flange on it.  I blocked it off with a rubber cap that I got from Checker Auto Parts, and a hose clamp.  Good luck.
'15 WRX
Reply #2August 19, 2006, 07:15:40 pm
BellCityDubber
  • 251
coolant pipe woes
« Reply #2 on: August 19, 2006, 07:15:40 pm »
Quote from: "rabbid79"
well, I already got the pipe, and it's the right one, it's practically new... and it came off a gasser, and the gasser and diesel oil filters are different (diesel is larger)
Reply #3November 04, 2006, 01:02:28 pm
Bludodger
  • 48
coolant pipe woes
« Reply #3 on: November 04, 2006, 01:02:28 pm »
BellCity-- Did you have to pull oil filter and cooler?
In the process of dropping my oil...
For anyone else with similar problem...
Pipe for A2 Turbo Diesel (with extra flange for oil cooler)---Part number is 027 121 065d and is still available new from certain parts companies...$25.
Reply #4November 04, 2006, 04:54:57 pm
anarchyx34
coolant pipe woes
« Reply #4 on: November 04, 2006, 04:54:57 pm »
I replaced mine with the engine out of the car so it was easier, but I didnt have to take the oil filter or oil cooler housing off. Maybe this pic helps?
Reply #5November 04, 2006, 07:46:19 pm
coolant pipe woes
« Reply #5 on: November 04, 2006, 07:46:19 pm »
It's old and garbage, pull out the angle grinder  :D
Now getting the new one in will be a pain, but you have half the battle done
I've done it before, I think I fed it up from below the oil filter but I can't recall
Reply #6November 06, 2006, 10:51:42 am
Bludodger
  • 48
coolant pipe woes
« Reply #6 on: November 06, 2006, 10:51:42 am »
Not sure if I had to do it but, since car needed oil change, I dropped oil and filter. The pipe slipped right in with extra space---did not have to touch cooler. No more leak. By the way anyone else have a problem with these pipes rusting out? From the looks of it ...it started from outside and worked its way right through. Luckily I the found the hole in my driveway and not in the middle of nowhere. :P
To moderators --- I think this post should be in troubleshooting
Reply #7November 06, 2006, 11:25:28 pm
BellCityDubber
  • 251
coolant pipe woes
« Reply #7 on: November 06, 2006, 11:25:28 pm »
Quote from: "Bludodger"
wow, talk about digging up an old thread... lol
yea, I managed to fix this one.. I had to do an oil and filterchange to get the tube out of the way..
the pipe tends to rust out (in?) at the point just above the starter....
