Author Topic: K24 Drain Line on 1.9 AAZ Problem  (Read 2562 times)
November 01, 2006, 06:45:44 pm
wolfsburgnut
  • 126
« on: November 01, 2006, 06:45:44 pm »
I am in the process of putting a K24 on my 1.9 AAZ and noticed the supply lines seem to be the same diameter, however the drain line for the K14 seems to be smaller.  I have an adapter to go from the K14 drain line to the K24, but Im wondering if the smaller drain line is going to be ok for my car.
Thanks
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
1986 Golf Wolfsburg Ed.
Reply #1November 02, 2006, 01:38:44 pm
wolfsburgnut
  • 126
« Reply #1 on: November 02, 2006, 01:38:44 pm »
Somebody must have experience with this problem???
Thanks
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
Reply #2November 02, 2006, 07:40:16 pm
andy2
« Reply #2 on: November 02, 2006, 07:40:16 pm »
You need a 1.6td drain pipe.Use the banjo fitting from the k14 pipe and the 1.6 pipe's upper half.connect the two different peices using a peice of hydraulic hose etc...
Reply #3November 03, 2006, 07:23:00 pm
SMOKEYDUB
  • 630
« Reply #3 on: November 03, 2006, 07:23:00 pm »
hydraulic hose....... what are you going to clamp that with?? even a single wall one is like impossible to actually clamp enough to not leak oil.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
