View full version: IDI Engine
  1. Camshafts
  2. Tuning for power vs economy????
  3. aaz pump throttle shaft bushing
  4. Its Running Again!!
  5. still nothing :(
  6. 1Y vs AAZ
  7. Valve cover oil control baffle
  8. Glow Plug Fuse Strip
  9. AAZ oil return size?
  10. Difference between TD and TDi
  11. tips for changing injectors on a AAZ
  12. My build sheet, 1.6l franken motor
  13. whats the diff internaly between the 1.9n/a and 1.9td...??
  14. Bypass filter question
  15. Retorque, or install arp studs? non leaking HG version
  16. I need exhaust mani. pics
  17. blowing return lines
  18. Product review: Aircraft Spruce EGT Thermocouple
  19. 1.9 Engine code location???
  20. Help has anyone got the pics for "make your TD a faster
  21. 1.6 Injection pump small bracket question
  22. 3" DP flange for T3 TD? Sources?
  23. Would anyone wanna see this?
  24. adding aba oil squirters to 1.6 n/a block
  25. idle getting scary now
  26. oil catch tank fitting help
  27. what are these wires for on the pump?
  28. scirocco 1.6 SB to AAZ 1.9...
  29. what is the comp ratio?
  30. Air flow requirements
  31. Oil Pressure Specification for 1.6 and search help
  32. LDA function test, 10mm head
  33. Random
  34. 1.6TD to 1.9TD - noobie questions
  35. 92 passat diesel
  36. Great, now I have a big choice to make...
  37. Need help with engine ID
  38. Turbo leaking oil into exhaust
  39. 1.6l n/a
  40. What should i do?
  41. Call to Tintin
  42. Any D24T guys here??
  43. is my turbo shafted?
  44. deleting preheated fuel filter? anyone?
  45. fueling
  46. Cold Start problems... have to push every morning
  47. Couple of questions: building oil pressure b4 1st startup
  48. turbo disassembly
  49. vacuum pump
  50. VW DIESEL INTAKES (PERFORMANCE)
