Author Topic: 1Y vs AAZ  (Read 3457 times)
January 10, 2009, 09:30:50 am
blunt
  • 22
1Y vs AAZ
« on: January 10, 2009, 09:30:50 am »
whats the difference between the two besides the obvious LDA and turbo manifolds, are the returns there and all, im looking to convert a 1Y to a AAZ basically
Reply #1January 10, 2009, 12:57:55 pm
1Y vs AAZ
« Reply #1 on: January 10, 2009, 12:57:55 pm »
apparently the oil return for the turbo isn't there, but you could drill & tap the block.  thats a pretty big tap though  :lol:
alternatively you could get a 1.6TD oil pan and just return it that way...
Reply #2January 11, 2009, 08:45:05 am
TurboJ
  • 661
1Y vs AAZ
« Reply #2 on: January 11, 2009, 08:45:05 am »
You will want to use crank, rods and pistons out of the 1Y engine - they are very strong and I would choose them over AAZ ones if I wanted to make power. You should also use the 1Y inlet manifold (flows tons better than the AAZ one ) - it can be used in conjunction with the AAZ exhaust manifold.
The 1Y also has an oil baffle, which is nice, and the cyl. head is basically the same. Just swap the injection pump and exhaust manifold and that's it pretty much. ( Oh and the AAZ oil pan which has the oil return bung on it ).
Jetta II 1.6 TD 'Project 200'
Reply #3January 11, 2009, 10:44:22 am
TurboJ
  • 661
1Y vs AAZ
« Reply #3 on: January 11, 2009, 10:44:22 am »
OK, I was thinking 1.6 TD once again  :oops:
So, 1Y block + 1.6 TD oil pan for the bung - easier to just an oil-pan fitted return connection.
