Author Topic: 1.6 Injection pump small bracket question  (Read 2170 times)
January 08, 2009, 04:53:20 pm
girl Mark
  • 17
« on: January 08, 2009, 04:53:20 pm »
Hi all,
I'm replacing an injection pump on an 84 rabbit and I now can't for the life of me figure out what this small, pressed-steel bracket is for (don't laugh).
It's very lightweight, and has a single small stud pressed in to one arm, with a hole for another bolt on the other arm.
 The hole/stud are about the same length apart as the bolt holes on the front mounting bracket of the pump, but I can't figure out how that would go together since the stud in the bracket would get in the way of one of the regular, heavier IP mounting bolts.
Help?
Reply #1January 08, 2009, 05:04:31 pm
girl Mark
  • 17
« Reply #1 on: January 08, 2009, 05:04:31 pm »
figured it out. What a weird design- it's basically an alignment bracket that holds the bottommost stud/bolt in place, in a place where you couldn't get a wrench normally.
 That stud is how the bottommost of the three mounting "bolts" in the front is attached. Did they design this pump for another engine originally?
Reply #2January 08, 2009, 05:07:03 pm
dillenger1
  • 777
« Reply #2 on: January 08, 2009, 05:07:03 pm »
Isnt their three of those?they triangulate the mounting surface of the IP.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #3January 08, 2009, 08:46:48 pm
girl Mark
  • 17
« Reply #3 on: January 08, 2009, 08:46:48 pm »
hmmm, that'd be bad news, I definitely didn't have three on this one. I assume they'd both connect to the one stud I just described?
Reply #4January 08, 2009, 09:23:44 pm
Rabbit TD
  • 840
« Reply #4 on: January 08, 2009, 09:23:44 pm »
Quote from: "girl Mark"
No, there is only 1 like that and you already figured out why they did it and you're right :D
