View full version: IDI Engine
  1. HARD starting when a little cold!
  2. engine noise
  3. weird cooling system problem II
  4. How to remove injectors?
  5. Backlit mk3 td gauges.
  6. Diesel Tach
  7. wanting a bigger turbo for a 1.9 td
  8. Rattly Rabbit! :D
  9. Non diesel question for a diesel 1.6 block
  10. 1980 VW 2 door rabbit convertible up for auction
  11. Chances of getting a 1.9TD in the US?
  12. rattly cars continued
  13. Can anyone translate german??? PDF format of manual
  14. Random timing belt question
  15. More power = More problems
  16. Motor Mount frustration :(
  17. Read this and tell me what you think
  18. intake heater
  19. Cruise control on 1997 TD
  20. Glow Plug System Checking?
  21. Time to change your oil
  22. Is this intermediate shaft usable? Picture
  23. cold start lever
  24. turbos yet again...
  25. 5 speed to 4 speed
  26. Cluster Swapping help
  27. Getting Max Fuel Mileage
  28. Aluminum Flywheel ?
  29. G-teched my td today
  30. 1.9/1.6 hybrid engine
  31. Turbo diesel injectors
  32. injection pump timing without timing tools??????
  33. Engine mounts
  34. O No!!!!
  35. Cylinder Head Date Code?
  36. What injectors to upgrade to?
  37. Bad day in the Caddy.....I want to CRY
  38. new glow plugs, new rebuilt injectors.... now smokes alot!!!
  39. oil pressure gauge
  40. bore out my block
  41. Hard start TD
  42. Pump problem after gov mod...
  43. Adding another fuel pump....just thinking
  44. Adding Cruise Control
  45. Will a 1.6NA head work on a 1.6TD?
  46. 1.9na vs. 1.9td
  47. pump pressure
  48. NEED HELP,
  49. VE pump diagram
  50. injectors?
