Author Topic: Hard start TD  (Read 4357 times)
November 09, 2004, 09:13:57 pm
935racer
Hard start TD
« on: November 09, 2004, 09:13:57 pm »
1991 TD, not eco diesel. Its a canadian version.
 I have to crank it over for at least 5 seconds and than it sputters to life and idles and drives fine from there on. I think its a fuel issue, It doesn't seem to make a difference wether I have the cold start oaut or not. Seems liek if I blip the throttle it starts a couple seconds sooner. Any ideas?
Reply #1November 09, 2004, 09:19:15 pm
Dr. Diesel
  • 1341
Hard start TD
« Reply #1 on: November 09, 2004, 09:19:15 pm »
if what you are describing is happening around the 0*c mark, it sounds pretty good! You can always check your glowplugs,  if one is burnt out, it's just enough to make starting hard in the cold, even with a good engine.
Reply #2November 09, 2004, 09:36:12 pm
Cheesetoast
  • 285
Hard start TD
« Reply #2 on: November 09, 2004, 09:36:12 pm »
is there an easy way to check my glow plugs? looks like the two far left ones are a pain in the butt to replace...
Reply #3November 09, 2004, 10:03:59 pm
Dr. Diesel
  • 1341
Hard start TD
« Reply #3 on: November 09, 2004, 10:03:59 pm »
i can't say for sure that it's 100% accurate, but so far, this method hasn't proven inaccurate for me yet. I remove the power bus from the plugs, connect my test light's clip to the positive terminal and then touch the ends of the installed glowplugs. burnt out plugs don't light up the tester. verify after removal by powering them on the bench.
Reply #4November 10, 2004, 07:28:25 pm
935racer
Hard start TD
« Reply #4 on: November 10, 2004, 07:28:25 pm »
Man I'm in San Diego, So its more like 65-75. Its warm, It seems to be getting worse, like its taking longer to start maybe it is glowplugs but it sure doesn't smoke much. And even after I run it for like 30 minutes and let it sit for 1 minute and than start it up again it has to crank over for at least 5 seconds... HELP
Reply #5November 16, 2004, 06:20:33 pm
dieselpower
  • 177
Hard start TD
« Reply #5 on: November 16, 2004, 06:20:33 pm »
hey,
my car has that same problem sometimes. not all the time tho. it seems if i give it like a quarter throttle right from the start it starts sooner, and also if i have my cold start advace out when the car is warm. it also seems to start better if i leave the key on and run a glowplug cycle before starting even when its warm. the only thing i can think of is maybe an air leak and it has to prime itself before it starts again? im not even sure if thats possible but it could be whats wrong.
good luck
Mark
84 rabbit 1.6TD
because real cars don't have sparkplugs
Reply #6November 16, 2004, 09:03:51 pm
fspGTD
  • 1529
Hard start TD
« Reply #6 on: November 16, 2004, 09:03:51 pm »
Quote from: "Cheesetoast"
Here's one way to check them (if you happen to have your injectors removed)...
Jake Russell
