Author Topic: Can anyone translate german??? PDF format of manual  (Read 3658 times)
November 24, 2004, 10:03:46 pm
« on: November 24, 2004, 10:03:46 pm »
I found this one a file sharing program off the net.   Its the german manual for 1.6L N/A + TD and also the 2.0L TD engines.
Turbolader = Turbocharger (I'll add that to my german vocabulary)
download it off my ftp here
http://members.rogers.com/harryfodder/SSP_043_Die_Turbo_Diesel.pdf
its very interesting.  Breaks down a lot of useful parts of the motor!  If only someone could translate :)
Jon
Reply #1November 25, 2004, 03:34:18 am
Dr. Diesel
  • 1341
« Reply #1 on: November 25, 2004, 03:34:18 am »
google has a translator. it's accessed through the 'language tools' button on their home page.  I think it works on straight definition translation, but it's often close enough to get the idea.
Reply #2November 25, 2004, 11:05:54 am
fspGTD
  • 1529
« Reply #2 on: November 25, 2004, 11:05:54 am »
Wow - that is great!  I had not seen that resource before.  Thanks for providing us with that (even if it is in german... more authentic!  :wink: )  If you can get it translated, I would love to see a copy of the english text as well...
thanks
Jake Russell
Reply #3November 26, 2004, 03:44:03 am
translating! yay thanks to google
« Reply #3 on: November 26, 2004, 03:44:03 am »
well i've begun work on translating the pdf file.  I'll just put it into an html webpage when I'm done.  The translation seems to be quite flawless!
sneak preview of the translation :)
Why turbochargers?
With the help of the turbocharger it is possible to use a large part for the heat energy otherwise escaping with the exhaust gases.  A further advantage is the increase and shifting of the torque into the range of lower engine speeds.  With an accordingly adapted transmission the following advantages result:
 - Lower of the engine speed at same speed
 - economy
 - decreasing the engine noise increased.
Contents
The system
Turbocharger
loading pressure control valve
loading pressure enrichment
Safety device for loading pressure control
Oil Circulation
The turbo Diesels in the comparison
Changes of construction unit
Hope you like it so far!
Jon
Reply #4November 28, 2004, 01:53:18 pm
web
  • 56
Re: translating! yay thanks to google
« Reply #4 on: November 28, 2004, 01:53:18 pm »
Quote from: "jtanguay"
hehe... I like it...
I would replace "loading pressure" with "boost", but that's just cosmetic ; this preview is quite understandable "as is".
Current car: '92 Fiat Croma TDID, similar to VW TDI only completely mechanical DI - with VE-style pump.
Previous car: '84 mk2 diesel, w/1.6TD swap ('86 hyd engine), 9mm plunger, KKK K24.
