» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Anyone over tighten oem vw rod bolts?
AAZ pump vs 1.6TD
opinions on saving a head.
IP Drive Shaft Seal
New mexican heads?
Need help, GTD pump going bad.
homemade 2.5" DP
question lda vs altitude compensator
INTAKE & HEAD PORTING ( EXTRUDE A HONE ) 1.9 AAZ
83' rabbit GTi (Diesel Build)
Priming '84 TD
Eco Dual Fan (where can I get a belt?)
K14-2 Turbocharger
advance lever - no noticable change in engine speed ??
Where to buy AUX belts in the UK
LUK Clutches
Plastigauge quaestion
AAZ vs 1.6td?
Glow plug light flashing
Air lines on turbo
95 GOLF TD
help - what is this solenoid for on my pump (not the shutoff either!)
Need pic of AAZ date stamp on block
AAZ how many with crank issue fixed? i dont see many?
1.6 NA Motor mount R&R pix or diagrams
Injector Questions
Where is the horn mounted?
pic of hood latch cable needed
Value of running AAZ
Weird sensor on my breather tube
AAZ bore/bearing specs?
AAZ injection lines
Questions on an alternate way of mounting a vnt-15
97 AAZ rod bolt question
my 1.9 na intake update
Industrial AAZ 1.9 TD Injection Pump
oil for break in
Traded my 98 Jetta shell...
installing connecting rod bolts
injector pump torque
82 Vanagon Diesel 1.9 idi 4 spd to 5 spd swap questions???
question about turbos
Where do these 2 pieces go?
DSL-1, rpm, tachometer etc settings
1.6 Cam
Overheated Slug?
When to drive normal?
Slow starting when warm
91 Jetta with K14 turbo - boost still remains low - what can be the problem?
Timing IP by ear
