Author Topic: Air lines on turbo  (Read 1879 times)
October 27, 2010, 08:34:27 am
Air lines on turbo
« on: October 27, 2010, 08:34:27 am »
I want to replace the short sections of air line on the turbo wastegate and to the BOV. Any recommendations on what type of line to use, or should anything the correct diameter from the local parts store work?
Also looking to replace the 90* rubber hose from the turbo to the intake. Any off the shelf silicone bits that work?
Reply #1October 27, 2010, 11:12:34 am
GEE-BEE
  • 1604
Re: Air lines on turbo
« Reply #1 on: October 27, 2010, 11:12:34 am »
silicone with a lined clamp
gb
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
