Author Topic: Injector Questions  (Read 3232 times)
August 14, 2008, 12:05:19 am
Quantum TD
  • 1195
Injector Questions
« on: August 14, 2008, 12:05:19 am »
So, I'm braving the injector rebuild for the first time. I acutally haven't decided if I'll buy rebuilt, or rebuld them myself. I get parts at cost, so that will be a factor.
My question is this:
Is there any reason why VW lists a a different nozzle (and rebuilt injector) between the Mechanical 1.6 NA and the Hydraulic 1.6 NA?
The reason I ask, is because I need injectors for a 1987 Hydro 1.6 NA, and the nozzles cost $18. each. But the nozzles for the 1.6 Mechanical NA are only $8.
If they're the same, then I'll probably rebuild and save some change buying the cheaper nozzles. But if I have to use the nozzles specified for the Hydro motor, the  I might just buy rebuilts.
Any clue to the difference? Breaking pressure?
Thanks
Reply #1October 21, 2010, 09:41:34 pm
Re: Injector Questions
« Reply #1 on: October 21, 2010, 09:41:34 pm »
Bumpity bump because I'm wondering too and I'm sure someone knows ;D.
Why different nozzles for hydro and mech?
Reply #2October 22, 2010, 04:51:51 am
Mark(The Miser)UK
  • 1557
« Reply #2 on: October 22, 2010, 04:51:51 am »
No reason at all. Batches, counter-productive 'progress'  ::)
Mark-The-Miser-UK
Reply #3October 22, 2010, 11:50:15 am
« Reply #3 on: October 22, 2010, 11:50:15 am »
Probably doesn't make a difference, but didn't we all figure out the precup size had changed between the original mech head NA and the hydraulic head NA?  Might explain the difference in nozzle part number...
Reply #4October 22, 2010, 03:06:10 pm
bigbillyboy
  • 16
« Reply #4 on: October 22, 2010, 03:06:10 pm »
where is the best place to buy nozzles?  I want to rebuild mine...
1985 volvo 760 with D24t
Reply #5October 23, 2010, 06:56:55 am
Mark(The Miser)UK
  • 1557
« Reply #5 on: October 23, 2010, 06:56:55 am »
A scrap yard, from a frontal victim. Get German/French ones.  All for the price of one, or less ;D
Mark-The-Miser-UK
Reply #6October 23, 2010, 12:14:38 pm
« Reply #6 on: October 23, 2010, 12:14:38 pm »
Rockauto has real bosch nozzles for like $11.53 each, the problem though is they make you buy 'em in packs of 10 so it's $115.30 for 10. Or you can pay 12.91 and get 'em each.
That's for mech heads. Hydro nozzles cost $22.99 each.
Reply #7October 25, 2010, 12:14:38 pm
