View full version: IDI Engine
  1. mk2 engine in mk1-downpipe?
  2. Triple gauge pods?
  3. Possible Upgrades
  4. Twin Photos
  5. nozzle for bosch kca17s42
  6. before i go any further
  7. Some basic questions
  8. id my turbos
  9. Heat shield is stuck in injector seat, now what?? NEED HELP!
  10. Am I the only one in the world with such a problem:(:(:(
  11. Turbo cool down?
  12. What metal headgasket for 1.6 mechanical
  13. turbo leaking oil exhaust side
  14. Turbo oil feedline
  15. HELP! quick. How do you collapse a lifter?
  16. Some ?'s for a N/A diesel 86 golf
  17. Clutches
  18. put in my boost gauge, think my waste gate is stuck
  19. Fuel Pump Question
  20. Oil Level Sender for my 1.6TD?
  21. engine temp vs speed question...
  22. LDA for gauge install
  23. IDI tuning question
  24. pyrometers?
  25. bleed valve on the line to the LDA
  26. MK1 GTD Downpipe Question...
  27. Ecodiesel
  28. intercoolers: g60, passat, and an audi 5k
  29. oil cooler question.
  30. Intermediate shaft bearing
  31. Turbo issues... repair or upgrade?
  32. where the heck did my post go?
  33. Rings
  34. Switching to synthetic at 470K
  35. plunjer question
  36. max fuel screw
  37. What is the best TD injection pump?
  38. '85 Quantum 1.6 TD FWD sedan; which way to go?
  39. bigger filter, more fun, i suppose
  40. Vacuum Gauge as Boost Gauge?
  41. Rebuild Kit for 1.6 IDI
  42. Effect of TD injectors in a NA engine.
  43. Aligning the throttle lever.
  44. Titanium
  45. To 2.5" or more...
  46. Will a 1.6 TD Mate/ Bolt to a Cable Shift/ Corrado Platform?
  47. my 1.6TD has a Garrett T-3 turbo - is this normal?
  48. stock TD turbo parts on my n/a for fuel economy?
  49. Turbo vs. non-turbo downpipe interchangeabiltiy question
  50. Which Filter to Use?
