Author Topic: Rings  (Read 3291 times)
April 26, 2006, 07:11:56 pm
X@V
  • 1002
Rings
« on: April 26, 2006, 07:11:56 pm »
After the bad compression test results, I decided to check my engine.
Everythings seems to be OK but I had 400PSI on two cylinders.
I would like to change the rings but I need to know which rings are good for a 1.9L TD? How much? Where?
Thanks
Reply #1April 26, 2006, 07:20:15 pm
SMOKEYDUB
  • 630
Rings
« Reply #1 on: April 26, 2006, 07:20:15 pm »
just changing rings wont do a hole lot you would have to deglaze the bore to get any good results.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2April 26, 2006, 07:29:07 pm
X@V
  • 1002
Rings
« Reply #2 on: April 26, 2006, 07:29:07 pm »
Yes I will do.
I have everythings to do it.
Reply #3April 26, 2006, 08:40:11 pm
hillfolk'r
  • 1532
Rings
« Reply #3 on: April 26, 2006, 08:40:11 pm »
http://www.vwdiesel.net/phpBB/viewtopic.php?t=3799
here ya go,,isnt 1.9 idi same rings as tdi???either way they can make them up for you
Throttle cables ftw
Reply #4April 26, 2006, 08:43:51 pm
X@V
  • 1002
Rings
« Reply #4 on: April 26, 2006, 08:43:51 pm »
Very interested...  :wink:
The ring set if for a 1.9L TDI?
PM me if you can ship them  :wink:
Reply #5April 26, 2006, 08:46:24 pm
wyldman
  • 403
Rings
« Reply #5 on: April 26, 2006, 08:46:24 pm »
OEM rings are $39.00 a hole,or $156 a set.I can ship them to you if need them.
(416)565-7282
Reply #6April 27, 2006, 05:17:06 pm
935racer
Rings
« Reply #6 on: April 27, 2006, 05:17:06 pm »
I sell the oem goetze onces for $28CAD a hole. I can ship as well.
Reply #7April 27, 2006, 07:48:34 pm
X@V
  • 1002
Rings
« Reply #7 on: April 27, 2006, 07:48:34 pm »
OK, OEM are good for my application.
That's what I will buy.
Thanks  :wink:
