View full version: IDI Engine
  1. 2 questions
  2. 1.6TD different turbo K03 or GT15?
  3. Vote for them!
  4. runaway on 1st startup
  5. smoke screw
  6. ko3s
  7. Vehicle Inspection Ticket
  8. Fuel issue
  9. injection clatter vs lifters clatter?
  10. 1.6 mls headgasket
  11. AC condenser question
  12. Finally replaced funny looking glow plugs with Bosch Duraterms
  13. where the hell do i find one of these?
  14. Tuning N/A 1.6D
  15. Can this be done??
  16. Giles Pump in a 1.6NA!
  17. Rebuilt Pump, RUNS AWAY!
  18. GM Injectors?
  19. How to break in, a diesel engine on a chassis dyno?
  20. compound turbo
  21. injection sensor from an AAZ pump used for a revcounter pickup????
  22. Best way to lower cr on idi?
  23. AAZ Serpentine Mod in a MK2 Jetta and the Cruise Control Servo
  24. Pre-cups - a solution?
  25. BOLT SIZE PLEASE ( LENGTH ) Upper alt bracket ( a/c) type
  26. correct 1.6 td injection pump throttle arm position?(picture inside)
  27. Diesel Swap
  28. Clutch pulley ( Alternator ) 028 903 119 AA
  29. pics of fmic install on mk1 rabbit? anyone?
  30. 1991 n/a alt set up
  31. cylinder head work
  32. Well its all gone pete tong!!
  33. How hard should it be to turn the IM shaft?
  34. my 1.6 TD build
  35. Fuel Line
  36. Radiator
  37. fuel injector pricing and where to buy
  38. Head studs/gaskets.. I know I know, its been asked a million times
  39. Cheap EGT sensor and guage kit
  40. 4 ganger clutch plate interchangeability [Quantum]
  41. GT1852V on 1.6?
  42. Vegetable oil heating in a diesel vanagon
  43. engine and transmission swap.
  44. Timing Belt and Cam Sprocket...
  45. MK1 1.9 dOWNPIPE
  46. Intermediate shaft
  47. car damaged during tow?
  48. Tell me what this is! Needle bearing, pilot bushing, or something else?
  49. 1.5 n/a injection pump on a 1.6n/a engine?
  50. bigger bore on a 1.6L
