Author Topic: 1.6 mls headgasket  (Read 2228 times)
August 28, 2010, 08:55:56 pm
myvolkswagen
  • 96
1.6 mls headgasket
« on: August 28, 2010, 08:55:56 pm »
I read that 53 willys ran one of these and from what i understand it is custom. How can I get one of these without going through a whole lot of trouble? Anyone else running one of these or something else that will hold up a little better than a stock hg? thanks
Reply #1August 28, 2010, 09:30:38 pm
Re: 1.6 mls headgasket
« Reply #1 on: August 28, 2010, 09:30:38 pm »
If you have a hydro head then just buy the correct thickness 1.9 aaz HG, it will bolt right up. If it is a mechanical head check out 53 willys stuff and he will tell you where to get stuff
OR
Saurkrat has some threads about blocking off the extra coolant passage. I did as well if you check my build thread.
http://www.vwdiesel.net/forum/index.php?topic=11786.45
http://www.vwdiesel.net/forum/index.php?topic=15780.0
Reply #2August 28, 2010, 09:41:21 pm
myvolkswagen
  • 96
« Reply #2 on: August 28, 2010, 09:41:21 pm »
Oh the aaz one will bolt up to the hydro 1.6?! Wow thanks you just saved me $100. Thought I would have to have it custom
Reply #3August 28, 2010, 09:52:21 pm
« Reply #3 on: August 28, 2010, 09:52:21 pm »
Yep 100% bolt on. Just measure for piston protrusion and you are in there like swimwear.
