Author Topic: Fuel Line  (Read 2040 times)
August 21, 2010, 09:37:03 pm
ffgb
  • 244
Fuel Line
« on: August 21, 2010, 09:37:03 pm »
Does anyone know where to get the fuel line that attaches from the fuel filter to the hard metal return line in a 1981 rabbit 1.6n/a?  The rubber hose is cracked bad and I don't what to splice in a connector piece, I would much rather replace the entire line.
Thanks
Reply #1August 21, 2010, 09:57:52 pm
maxfax
  • 2126
Re: Fuel Line
« Reply #1 on: August 21, 2010, 09:57:52 pm »
You can replace just the rubber part..   IIRC it's 5/16" fuel line..  Although I'd opt for something made with viton or nitrile like low pressure hydraulic hose, or high pressure fuel line (for EFI)..    You'll have to grind/cut the crimp that holds the rubber to the banjo fitting that attaches to the filter..   THen just use a regular ole hose clamp to re attach..   It shoudl already just be clamped to the fuel line on the car..
Reply #2August 22, 2010, 09:24:00 am
GEE-BEE
  • 1604
Re: Fuel Line
« Reply #2 on: August 22, 2010, 09:24:00 am »
7MM BLACK VW CLOTH TYPE
AUTOHAUSAZ.COM
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3August 22, 2010, 01:56:48 pm
ffgb
  • 244
Re: Fuel Line
« Reply #3 on: August 22, 2010, 01:56:48 pm »
Thank you.  I guess I'll go the 7mm Autohausaz.com route.  I have to order a radiator for my 1981 1.6n/a and a couple of oil filter housing gaskets, I'll just add to the order.
Reply #4August 22, 2010, 08:30:04 pm
GEE-BEE
  • 1604
Re: Fuel Line
« Reply #4 on: August 22, 2010, 08:30:04 pm »
Replace all the hoses and new coolant
the new silicone 068121053E hose will be available next week from greasework's, it's a1/2 longer per jack's build "
Pump to Head ( coolant Hose )
7.5 mm coolant hose, radiator nipple to coolant tank
443121107A
If you need a hand let me know...
GB
« Last Edit: August 22, 2010, 08:33:00 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
