View full version: IDI Engine
  1. Battery Sizing
  2. Engine stalled in a cloud of white smoke?
  3. Valve seals tubes
  4. Valve guide clearance? Experts needed
  5. car runs too cool...SOMETIMES
  6. 1991 Golf 8v gasser to 1.6TD swap!
  7. Head Gasket Replacement?
  8. AAZ Dowel Crank fix now no start
  9. Custom 2.5 exhaust design question
  10. Coolent Flow Problem
  11. Different Prechambers PIC
  12. AFN?
  13. logistics of running a Giles'd TD pump on a NA?
  14. piston projection too high on one cylinder
  15. AAZ knocking/timing
  16. Turbo I found, is it something I want? Garrett T3
  17. Got an engine question turbo engines
  18. Dawes valve question
  19. Stretch (torque to yield) Bolts on 1.6NA
  20. Oil pump pickup interference with 1.6td oil pump on an n/a pan.
  21. Two 1.6L mech head rebuild questions
  22. Swain Tech is GOOD stuff....
  23. Operating oil pressure
  24. IP Shaft Seals
  25. I need a straight answer! How much boost is safe???
  26. Almost ready to swap transmissions 4sp to 5sp
  27. the fuel filter!
  28. Xtreme 4x4 and Performance Diesel Injection
  29. AAZ governor mod?
  30. Trubo hot side problem
  31. audi 5000 diesel and a k26?
  32. Performance cam for mechanical heads
  33. 1.6td value
  34. Turbo upgrade, which one.
  35. RadoTD's EGT and boost gauges
  36. What is the best exhaust setup?
  37. Water pump idler pulley
  38. a few moar n00b ?s
  39. Is the vac pump supposed to move?
  40. Will a Beetle 1.9 turbo fit?
  41. need info on GTD high output engine?
  42. 1.6 TD combustion prechambers (new) are available
  43. Different size wheels on one axle?
  44. How to remove turbo
  45. Bosch nozzles
  46. Headbolt or stud question
  47. I bought an AAZ trying to comp test, what starter to use?
  48. Mech head on Hydro block??
  49. NA IP vs TD IP
  50. 95 Passat AAZ tranny swap
