Author Topic: Operating oil pressure  (Read 2505 times)
May 05, 2011, 11:32:30 pm
gnavs
  • 340
« on: May 05, 2011, 11:32:30 pm »
I'm nearing completion of my AAZ rebuild and am monitoring my oil pressure.  Seems like I'm getting around 50psi at startup, dropping gradually to around 40psi after a couple minutes.  What's normal operating pressure for these engines?  I've read anywhere from 15-80 psi depending on temperature and oil type.  I'm using 15W40 Lubromoly at the moment.
Thanks.
Reply #1May 06, 2011, 01:39:14 am
zagarus
  • 619
Re: Operating oil pressure
« Reply #1 on: May 06, 2011, 01:39:14 am »
cold startup I see it anywhere from 80-100psi, once oil is warmed up to operating temp it should sit around 22-30psi at idle.  Cruising around you're looking around 40-60psi.
Reply #2May 06, 2011, 03:35:45 am
vako
  • 187
« Reply #2 on: May 06, 2011, 03:35:45 am »
i am getting 8-10 psi  (0.5-0.7 bar) at idle when fully warmed up. but i do not have oil cooler and now im using quite cheap 15w40 mineral oil.    i think that synthetic or semi-sinthetic oil should give me more pressure.    i have that readings at oil filter flange.   i get 60-70 psi at cold startup.
engine AAZ
Reply #3May 06, 2011, 05:20:10 am
« Reply #3 on: May 06, 2011, 05:20:10 am »
I have the same as zagarus and I am running 5w-40 rotella T6
Reply #4May 06, 2011, 06:05:46 am
nathan_b
  • 361
« Reply #4 on: May 06, 2011, 06:05:46 am »
how are you measuring it? known good mechanical gauge or a vdo guage
Reply #5May 06, 2011, 08:17:31 am
gnavs
  • 340
« Reply #5 on: May 06, 2011, 08:17:31 am »
I picked up an autometer electric pressure gauge on ebay last year and it seems to be working fine.  I trust it more than the army of blinking lights in my cluster  ;D
Reply #6May 06, 2011, 12:13:37 pm
vako
  • 187
« Reply #6 on: May 06, 2011, 12:13:37 pm »
and i have tractor mechanical gauge :D  bought for just 6$
