Author Topic: Different size wheels on one axle?  (Read 9177 times)
April 26, 2011, 12:19:50 am
Torchd
  • 372
« on: April 26, 2011, 12:19:50 am »
Hey guys!
I have a mkIII AAZ and  I wanted to ask if I can run two different sized wheels on the front axle?
Is it safe to run it or will I be causing damage to the diff?
My spare is a space saver design so everytime I use it I *** my pants!
Please help.
Reply #1April 26, 2011, 02:57:05 am
maxfax
  • 2126
Re: Different size wheels on one axle?
« Reply #1 on: April 26, 2011, 02:57:05 am »
It's not good for the diff at all..   Very short distances at low speeds is all that "donut" spare is really intended for..  IF you don;t mind giving up a bit of trunk space, a full sized spare is darned nice..  If you have to travel any distance on your current spare, and it's at all possible, put the spare on the rear, and move one of the rear tires up front..
Reply #2April 26, 2011, 09:18:24 am
« Reply #2 on: April 26, 2011, 09:18:24 am »
x2, if you gotta drive more than like 10 miles, or over 40 mph, put the donut on the back and run a rear tire on the front end, then the spiders wont be constantly turning in the 3rd member..
Reply #3April 26, 2011, 10:23:56 am
Torchd
  • 372
« Reply #3 on: April 26, 2011, 10:23:56 am »
Right..
So the front tires have to have the exact same circumference or can it be a little different?
Reply #4April 26, 2011, 10:26:15 am
« Reply #4 on: April 26, 2011, 10:26:15 am »
Right..
if the front tires are different sized (1/2" or so probably wont even matter) then the spiders in the 3rd member will always be turning, and will wear them, and the conical washers..
think of it this way.. if you have differently sized tires on the front of your car, it will think you are constantly driving in circles. the differential doesnt know any better..
Reply #5April 26, 2011, 09:33:11 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: April 26, 2011, 09:33:11 pm »
I think overall diameter might be prudent to mention here. If both tires have the same rolling radius, it should not affect the drive-train at all. Granted, a death donut is not for autocrossing, but it shouldnt have an adverse effect on the differential if it has the same overall diameter.
Perhaps the term 'tire size' should be clarified...
Reply #6April 27, 2011, 09:14:55 am
« Reply #6 on: April 27, 2011, 09:14:55 am »
correct, if you have 2 tires that are ~ the same diameter.. it will work. we were running a 185/70/14 on my buddies Audi 90Q, and the other 3 tires were 205/40/17s... there wasnt enough diameter difference for the car to care..
Reply #7April 28, 2011, 06:09:38 am
Torchd
  • 372
« Reply #7 on: April 28, 2011, 06:09:38 am »
Okay!!
I had to run 205/60/14 on one side and 185/70/13 on the other on front axle for about 8 kms. Did I damage my diff or am I alright?
Reply #8April 28, 2011, 06:32:23 am
« Reply #8 on: April 28, 2011, 06:32:23 am »
nope, they are about the same rolling wise and that isn't that far. You would need a bunch of offset and much more distance to hurt it
