» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Cranking when hot engine
Help, IP leaking can I make it home?
hybrid isuzu/cummins pump finished!
Rod bearings?
AAZ Conversion
after engine is warm it wont re start help
http://dieselvw.com ?
Porting Manifolds, how thin is too thin?
Front bumper removal
Wiring in the engine bay
Connecting rod bolts
92 eco to td
Tips/Tricks for priming Older A2 style filter (non heated)
Injection pump question.
Turbo Back pressure?
Injection pump question (what's this part do?)
1.6TD boost pin in AAZ
lint
Bearings on crank too big? Crank hard to turn by hand
Waterpump differences?
This is getting old ........
My bro has an amazing TD
Source for parts great quality
How common is a broken throttle lever?
new design for precups
quick diagnosing help needed
Turbo oil line fittings
Using non-VW LDA top on a AAZ pump without a LDA?
Alternator Talk
IT LIVES !!! Kinda...
siezed my engine last night...
GAS MILEAGE WHAT TO DO?
Best turbo for 1.9 AAZ in VW Camper
pump timing gauge in inches and not mm help
coolant lines
TD Pump more fuel then N/a
looking into a Wolverine pan heater...
noise in 1.9td
K03 turbo information
Crank bolt torque figures
Exhaust brakes ???
VE pump gurus/builders come inside please!
Intercooler install! (mazda millenia unit on rabbit)
Coolant Hose Mod for 1.9 AAZ , ( Aftermarket Oil Cooler Install )
V8 diesel from an Audi 3.6/4.2 ?
T3 w/ gas exhaust and TDI intake
Chocolate Milk with a side of gauges..
Dead block heater
AAZ or any downpipe measurements question. ID or OD
changing headgasket
