Author Topic: Front bumper removal  (Read 1916 times)
February 03, 2011, 11:51:47 am
jpedro
  • 137
« on: February 03, 2011, 11:51:47 am »
how do you remove the front bumper cover, im trying to figuree it out but i cannt seem to get it out? any suggestions its a 1990 jetta
1990 VW Jetta 1.6L TD 235000kms Custom cold air intake and Custom 3" straight pipe
1992 Ford F250 7.3L IDI custom everything you can possibly think of. ( my braging rights are live with this toy)
Reply #1February 03, 2011, 12:56:53 pm
rodpaslow
  • 670
Re: Front bumper removal
« Reply #1 on: February 03, 2011, 12:56:53 pm »
You need to remove the complete bumper if you haven't.  If it's an aftermarket one there will be a few screws and plastic clips holding it on.  An original vw one I think is just clipped on, not 100% sure of that.  But it will be easy to see once you have the bumper off.  Two bolts on each side of the front crossmember from below the car and one horizontally in from the side.  These are a bit harder to get at from underneath.
