Author Topic: T3 w/ gas exhaust and TDI intake  (Read 3916 times)
January 06, 2011, 07:12:22 pm
coke
  • 254
« on: January 06, 2011, 07:12:22 pm »
I'm in the process of collecting parts to bolt a T3 to an 8v gas T3 exhaust manifold, and if I can't locate a suitable 1.6 turbo intake, I plan on using the TDI intake manifold. I know the TDI manifold uses D ports, but I'm not running a turbo pump, or high boost. Kinda like an eco diesel setup.
Will there be any issues bolting a TDI intake to the engine with the 8v t3 gas manifold?  I'm thinking something like this:
http://cgi.ebay.com/ebaymotors/VW-8V-CAST-IRON-TURBO-EXHAUST-MANIFOLD-GOLF-JETTA-T3-_W0QQcmdZViewItemQQfitsZMakeQ3aVolkswagenQQhashZitem4155adfe29QQitemZ280610340393QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_1677wt_939
Intake would be this:
http://cgi.ebay.com/ebaymotors/New-VW-TDI-Intake-Manifold-Golf-Jetta-IV-99-04-_W0QQcmdZViewItemQQhashZitem4cf44ef554QQitemZ330516329812QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_1240wt_1165
The exhaust ports seem slightly wider than the diesel ports (metal material outside of the ports themselves) and I'm wondering if there will be some interference issues that might need modification to get the manifolds to bolt up correctly.
Now, I'm fairly certain after the turbo is bolted on that I should still have some room between the turbo and the firewall. Albeit, not much, but some, right? Anyone else ran a similar setup that has any advice on clearance issues?  Thanks in advance.
Reply #1January 06, 2011, 07:54:56 pm
GEE-BEE
  • 1604
Re: T3 w/ gas exhaust and TDI intake
« Reply #1 on: January 06, 2011, 07:54:56 pm »
get a 1.9 aaz intake and exhaust ( K14) same as T2/T3
You can always run a 1.9 head
Ebay germany is a good start
you might pay 85.00 for both, shipping 65.00
Options intakes
PD130 inlet LH , easier to to mod for intercooler
PD150 faces RH
Either way you will have to get a race pipe ( egr delete )to make any of the tdi or pd series to work
I hope you get things that fit , save time and money
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2January 06, 2011, 08:06:22 pm
« Reply #2 on: January 06, 2011, 08:06:22 pm »
The T3 won't want to bolt to that manifold. Not the VW T3 anyway. It has a trapizodial shape.
Reply #3January 06, 2011, 08:27:29 pm
coke
  • 254
« Reply #3 on: January 06, 2011, 08:27:29 pm »
This is from a 300D benz. And, from what I can see, its alot larger. It clears, but doesn't leave much room.
Reply #4January 06, 2011, 09:01:03 pm
mystery3
  • 774
« Reply #4 on: January 06, 2011, 09:01:03 pm »
I'm in the process of installing a similar setup except I have a Gilesified turbo pump, t3 from a bmw 524td and I'm running a g60 manifold with one of these http://www.bahnbrenner.com/vw_audi/products/1949/MkII_T_Body_Adaptor_to_3 adaptors. Why not just run an 8v gasser manifold? You may have to do some "trimming" to fit it with the turbo but they're readily available in the junkyard and the ports line up.
Reply #5January 07, 2011, 07:40:14 am
GEE-BEE
  • 1604
« Reply #5 on: January 07, 2011, 07:40:14 am »
I was thinking , just purchase the turbo and both manifold's from  germany and your done
easy fitment
GB
Spend a litttle more than that tdi manifold and get a PD model
Giles Pump OHC
MK1 JETTA DASH
