Author Topic: Chocolate Milk with a side of gauges..  (Read 5077 times)
December 19, 2010, 03:57:43 pm
jaysen71581
  • 211
    Hagerstown, MD
« on: December 19, 2010, 03:57:43 pm »
Well just as it says, i made a noob mistake and forgot to torque the head to the proper spec and when i finally got it running i made my new special blend of oil and antifreeze, thankfully we caught it and i was able to drain both the coolant and oil.  I went to the local autoparts shop and bought Motor Flush made by Gunk, the person at the counter said to run it for about 5 mins drain and do it again with out motor flush, does that idea sound good any thoughts or am i just screwed...
Part 2
I have the center console out of a Cabrio and it has the VDO gauges, will they work with my stock sending units?  If not should i just go with like this with its own gauge sender unit:
http://www.autozone.com/autozone/accessories/Sunpro-2-in-0-to-100-PSI-electrical-oil-pressure-gauge/_/N-25ls?aqs=4294862105&counter=5&filterByKeyWord=gauge&fromString=search&itemIdentifier=630658_0_0_
Reply #1December 19, 2010, 04:42:27 pm
Re: Chocolate Milk with a side of gauges..
« Reply #1 on: December 19, 2010, 04:42:27 pm »
cabby gauges need cabby sending units.
follow the directions on the back of the jug for the engine flush.
Reply #2December 19, 2010, 04:54:37 pm
« Reply #2 on: December 19, 2010, 04:54:37 pm »
also before you start it again, tighten your head bolts to the proper specs   :P :P :P :P :P
Reply #3December 19, 2010, 05:26:28 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #3 on: December 19, 2010, 05:26:28 pm »
I re-tightened them after i saw bubbles between the head and the motor that's when i dove into the bentley and saw i missed the final step, i re-torqued and no more bubbles.  I think it took me 3 days after the initial start-up before i did the motor flush today...  Thanks R.O.R-2.0  i guess ill go with the sunpro gauges and tap out everything to standard thread...
Reply #4December 19, 2010, 08:46:26 pm
BigVWman
  • 332
« Reply #4 on: December 19, 2010, 08:46:26 pm »
the sender for the cabriolet gauges are standard vdo and readily available, check 42draftdesigns they usually are fairly cheap or your local pick and pull. It will fit you existing thread in the cylinder head.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #5December 20, 2010, 09:03:44 am
« Reply #5 on: December 20, 2010, 09:03:44 am »
yea, even standard threads fit in the metric vw threads..
Reply #6December 21, 2010, 06:47:56 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #6 on: December 21, 2010, 06:47:56 am »
We've had some cases of inadvertent filling of oil in radiators or oil/coolant cross-contamination through coolers, and the Cummins and MTU Detroit Diesel recommendations were always to use washing soda in the coolant system to remove all traces of oil.   It takes several cycles of water and washing soda to get the passages cleaned, but it doesn't foam up like soap products would.
For the oil system I would go with what was recommended.
Calvin
91 VW Golf 1.6NA 5spd
Reply #7December 21, 2010, 07:13:09 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #7 on: December 21, 2010, 07:13:09 am »
So the new sender units will just screw in like they are suppose to without tapping???  If so then ill have me some gauges up and running in no time.....
What kind of washing soda?
Reply #8December 21, 2010, 07:16:49 am
« Reply #8 on: December 21, 2010, 07:16:49 am »
well, the threads are NOT the same on aftermarket gauges, but are VERY close. so if you use teflon tape, ive had no problem with leaks, or damaged threads. its basically the same threads, just the metric threads are not tapered.. just straight in.
cabby senders will screw right in the head, and work with your gauges no problem..
« Last Edit: December 21, 2010, 11:44:41 am by R.O.R-2.0 »
Reply #9December 21, 2010, 11:41:27 am
BigVWman
  • 332
« Reply #9 on: December 21, 2010, 11:41:27 am »
If this is a play on when i said "standard vdo" that would mean nothing special vdo not "standard" threads, they are a metric m10x1 iirc MY point was that a simple vdo sending unit from many vws fitted with a gauge will fit his head, as it should properly. As well they are available from vdo new.
« Last Edit: December 21, 2010, 11:44:50 am by BigVWman »
Tim
Reply #10December 21, 2010, 11:48:41 am
« Reply #10 on: December 21, 2010, 11:48:41 am »
sorry, i was not awake this morning. and was talking about aftermarket senders with 1/8npt
Reply #11December 21, 2010, 02:48:57 pm
rumbling_caddy
  • 80
« Reply #11 on: December 21, 2010, 02:48:57 pm »
   When I installed gauges to my diesel caddy with a cabby dash swap I went to http://egauges.com and got the matching vdo senders.  They have a wide selection at good prices.
« Last Edit: December 21, 2010, 02:51:28 pm by rumbling_caddy »
Reply #12December 22, 2010, 05:46:13 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #12 on: December 22, 2010, 05:46:13 am »
Ive found a set of metric adapters for the sunpros, i was looking at my vdo gauges and they look kinda rough, what size are those gauges that came in the Cabrio's? i was thinking 2 inch..
Reply #13December 22, 2010, 08:51:47 am
BigVWman
  • 332
« Reply #13 on: December 22, 2010, 08:51:47 am »
The stock triple gauges in the cabriolets are 2" they actually measure around 2 1/8" but they call them 2".
Tim
Reply #14December 23, 2010, 04:47:18 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #14 on: December 23, 2010, 04:47:18 pm »
To be honest I don't remember the brand, just went to Walmart and bought the only one they had on the shelf.
Calvin
