» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
please help!!
Quick head bolt questions
Dynoed my NA Golf with a Giles pump!! Dyno POSTED
headgasket for 40 over rebuilt motor???
96 Golf 5spd
Thermostat question
converting a 1991 Jetta GLI to a 1.6 TD?????
Best way to re-wire rad fan.
Help me find a good pyro...
Does this work for my 96 Golf AAZ?
Poll: Time for more boost?
questions about my ecodiesel
build a 2.1L idi diesel What head gasket ø=83mm
1.6L Timing advance curve mod...
2.4 pistons for 1.6
Dealing with Sludge
bosch injector nozzles
Gov Mod a few pics and some questions about boost
lucas oil treatment
questions for "Turbinepowered"
Head and sump off, this is what I find!
I am rebuilding a 1.6L motor, suggest parts please
Motor runs away on my 83 Rabbit
leaking injection pump
need downpipe for 92 eco diesel
Ohio Gathering (UPDATED WITH DIRECTIONS AND MEETING LOCATION
Strangeness I say!!
my IP needs help
turbo: shaft play, low boost, oil leak questions
valve spring retainers, where to buy?
1.6 Eco Valves different from 1.6TD Valves
So i know they are supposed to smoke
Hole in exhaust manifold mk2 golf/na
Do exhaust in coolant testers work on diesels?
cam belt wear
Lighted flywheel
Excessive Intermediate Shaft Play
Compund turbos on a 1.6???
Volumetric efficiency of 1.6td?
Blow by checks?
Sonic testing for wall thickness
Gov mod failure
Transmission oil Top up?
LDA Feeler pin--not ramped boost pin
Whats this?
Too Much Boost ?
Int/Exh port numbers.
thermostat location?
Injector Pump lift & timing concept question
late 1.6 IP question
