Too Much Boost ?
Topic: Too Much Boost ? (Read 2562 times)
August 02, 2008, 03:20:15 pm
Riverfurm
Too Much Boost ?
August 02, 2008, 03:20:15 pm »
I think I found my coolant leak and overheating problem. I run about 20 psi max. Got a short block comming.
http://riverfurm.smugmug.com/gallery/5602298_SECiE#343803793_af8Dm-A-LB
http://riverfurm.smugmug.com/gallery/5602298_SECiE#343803787_3Dxsf-A-LB
How do I get these picture in my text?
Riverfurm on the Delware
86 Golf 1.6 Turbo, Giles IP, Pass 3"dp and 3"ex
Fleet of Ford Diesels and Case Equipment
August 03, 2008, 04:22:17 am
Riverfurm
Too Much Boost ?
August 03, 2008, 04:22:17 am »
Thanks for the info Andrew. Three head gaskets one new head and a head stud kit later I found the crack. It almost seems the head bolt hole was clogged with dirt and the head bolt was tighten down and bottom out on the dirt cracking the block. I chased the threads with a tap and installed the studs by hand. The crack was hard to find due to the IP bracket in front of it.
August 03, 2008, 06:35:44 am
foxracer1
Authorized Vendor
Too Much Boost ?
August 03, 2008, 06:35:44 am »
It is possible to hydro lock the stud in the hole if it has a liquid in it. That could cause it to crack.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
August 03, 2008, 06:48:45 am
DieselKraut
Too Much Boost ?
August 03, 2008, 06:48:45 am »
Its very possible. I watched it happen on a Series 60 Detroit. It wasn't the head bolt hole but one it the gear case. It got hydro locked and busted a chunk off and sent it flyin across the shop.
In this case it could have been only slightly cracked from when the original head bolts were used and then grew form there. I'm sure with cracks that big a popping noise would have been heard.
'80 Rabbit 1.5 IDI 126,00Mi Down but not out!
'83 Quantum 1.6 TD IDI
'90 Passat Gasser
August 03, 2008, 01:59:43 pm
Riverfurm
Too Much Boost ?
August 03, 2008, 01:59:43 pm »
I think the IP bracket bolt had dirt in it and started the crack. They were very hard to get out.
August 03, 2008, 03:19:11 pm
Sierra94
Dieselsmoke in every stroke... M-Tdi Mazda!!
Too Much Boost ?
August 03, 2008, 03:19:11 pm »
Always, always blow all holes with compressed air and use a tap and then blow again to get all grit and dirt out of the way.
<-- My M-tdi Mazda B-1800 and
my other cars
Too Much Boost ?
