» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Timing AAZ with adjustable IP sprocket out of car---no flywheel
Smoking at part thorttle
T'ing off crankcase vent?
Sources for bare heads
more advance=less cranking?
Replacing Rings Need Info
WINTER BEATER BUILD !!
Anyone have the AC working?
Coolant flush, what is capacity?
Turbo, or head causing blue smoke?
cylinder head print?
Test your Smarticles.... How much do you really know?
Turbo choice
AAZ head rebuilding questions
How Do You Hook Up the ALFB on the Injection Pump
MK2 1.6 into a MK1 rabbit
Red Line 15W50 Motor oil
AAZ timing belt route
White Smoke/ Very High EGT's
A how to question???
fml... anyone have a 210 flywheel?
takes a couple of cranks to start??
help me select a proven turbo setup for my build
95 AAZ Passat issues
1981 1.6na engine
Different cooling system setup
pop taster TIP
Smoke
Intercooler Reservior for air to water cooler
Passenger Performance 1.6td intake manifold
1.6L diesel head swap ??
electric pump needed
whitish smoke at hard throttle.....
1990 1.6TD Battery Light is ON, but Battery is still charging.
My GTD passed tech inspection!
1.6 11mm mech / 1.5 bottom / 1.6 pump
Diesel engine in gas car tach question
New To The Forums - Fresh New 1.6 TD Build
1.6 Delivery Valves....Want to sell? Or kindly help?
Considering an 87 Jetta TD, need advice
Injector Pump Timing Help
Air Conditioning
Cleaning out the fuel system
Ceramic Coating
AAZ main bolts/con rod bolts (yes I looked at the FAQ)
Possible Swap
1.9 td EGR
turbo oil return leaking at oil pan.
Could use some help..
Whump, whump, whump from intake...?
