Author Topic: Intercooler Reservior for air to water cooler  (Read 2346 times)
June 26, 2010, 06:24:35 pm
rodpaslow
  • 670
« on: June 26, 2010, 06:24:35 pm »
I've gone through whats on the site and I've seen someone with a 3 gal reservoir tank.  I'm planning on putting just a 1 gal tank.   What is too small.   Is a gal not enough?  I figure one everything is full that will be about a gal and a half.
Does anyone know how hot the air is at a boost of about 15 to 20 psi is once the engine is warm?  I know that will vary slightly with air temp, but will it add roughly a certain amount of temp.
Reply #1June 29, 2010, 02:44:11 pm
TurboJ
  • 661
Re: Intercooler Reservior for air to water cooler
« Reply #1 on: June 29, 2010, 02:44:11 pm »
Reservoir: bigger is better, smaller is worse.
Air temperature: entirely dependent on the turbocharger. Pressure is just half the story, turbocharger type is the other half.
Jetta II 1.6 TD 'Project 200'
Reply #2June 29, 2010, 02:59:47 pm
« Reply #2 on: June 29, 2010, 02:59:47 pm »
I have heard of temps ranging from 150 to 350 on the air. I am a turbo noob and am looking into this as well. I will be watching to see what you find.
Reply #3June 29, 2010, 09:44:03 pm
Otis2
  • 191
« Reply #3 on: June 29, 2010, 09:44:03 pm »
I think a gallon of fluid circulating is going to be plenty.
If this is a drag-strip car, then sure, big reservoirs are the way to go, and you can ice the hell out of them if you want to get fancy.
But for a daily driver, a big reservoir won't do as much.  You're going to eventually heat up all that water anyway, and it takes just as long to cool down as it does to heat up.
Factory A2W ICs for a street vehicle, like on a GMC Syclone/Typhoon, don't have big reservoirs.  The Sy/Ty IC reservoir is tiny, about a one-half litre bulge at the side of the IC, with a 13 psi pressure cap.
I think that a really big heat exchanger (mini-rad) would be more useful than a really big reservoir on a street car.
« Last Edit: June 29, 2010, 10:05:33 pm by Otis2 »
Reply #4June 30, 2010, 09:04:33 pm
Henchman
  • 183
« Reply #4 on: June 30, 2010, 09:04:33 pm »
Buddy of mine has  a SHO with a 40l cooler in the trunk.  For drag runs, he fills it with ice.  Get 2-3 runs before it's all melted.
Ian
