Author Topic: AAZ timing belt route  (Read 6528 times)
March 14, 2010, 11:34:21 am
1outof5
« on: March 14, 2010, 11:34:21 am »
could you confirm please that is the layout of the timing belt, thanks
it's going into a mk1 and after having installed the engine mount the belt looks like its' real close to rubbing together between the mount and the intermediary sproket ...
Reply #1March 14, 2010, 11:44:17 am
Re: AAZ timing belt route
« Reply #1 on: March 14, 2010, 11:44:17 am »
Yes it will come very close to the mount... but you should be fine.  You'll also find it's a tight fit side-to-side, but again it will work.
What kinda MK1 are you dropping it into??  Inquiring minds want to know...  ;) ;D
Reply #2March 14, 2010, 01:07:24 pm
1outof5
« Reply #2 on: March 14, 2010, 01:07:24 pm »
thanks for the confirmation  8) takes a wheight off my chest  ;D
it's going into a mk1 caddy, bought it off a farmer you had "botched" the job of putting in a "JR" 1.6TD using the wrong engine mounts, belt and gearbox side, only had 4 of the 5 gears etc etc. finaly it used more water than diesel so convinced my wife that it would be cheaper to just buy another engine than do the head/gasket ... and went and bough a "RA" 1.6 TD.
installed with a renault safrane IC and the thing made a racket !
In the meantime my dad crashed my sisters B3 AAZ passat sooooooo I'm putting in her engine  ;)
not done yet, was supposed to be a quick job ... that was last winter. now I'm trying to get thing done bit by bit when I have the time.
Intalled PS aswell.
Once the caddy is back on the road and be rebuilding the "RA" engine with a Giles superpump (I've already got it)
Reply #3March 14, 2010, 04:53:52 pm
macka
  • 957
« Reply #3 on: March 14, 2010, 04:53:52 pm »
Did you know at the time that you were lying?   ;D
Like all of us guys the ends justifies the means  ;D
Quote from: Vincent Walden
Reply #4July 02, 2010, 04:30:32 am
Darkness_is_spreading
  • 288
« Reply #4 on: July 02, 2010, 04:30:32 am »
Hey, does your passenger mount extend out to & hold the IP?
It looks like you modified a MK1 1.6 Passenger Motor Mount and reduced it so it has 4 points of attachment....
92 Jetta 1.6 T (Sleepin)
Reply #5July 03, 2010, 06:15:01 am
1outof5
« Reply #5 on: July 03, 2010, 06:15:01 am »
no it's a gas MK1 engine mount, easier than cutting up a diesel one. the AAZ doesn't need the full bracket because the pump is not mounted the same way.
