Author Topic: White Smoke/ Very High EGT's  (Read 6876 times)
June 23, 2010, 11:28:11 am
GTD_MK2
  • 21
    Smoke...
« on: June 23, 2010, 11:28:11 am »
Hi!
I've got some Problems with my TD,
When its cold, it starts good with or without the advance, but gives a little bit white smoke in idle and part throttle.
When its warmed up the smoke in idle is gone, but there is still a little bit of white smoke in part throttle and more under WOT .
Also when im on WOT and rev it over 4k RPM, regardless of fueling, it has a very high egt (up to 1750°F), and even when i turn the fuel up more, i cant get more than 25 psi Boost
I've got New GTD Nozzles, varied the timing, tried 2 other pumps, and changed from the KKK K14 to the K24 turbo, but the problems are still the same...
My biggest problem are the massive EGT's, so has anyone an idea how i can get them down ?
A Diesel has to smoke !
1991 Golf Mk2 GTD,(ex EcoDiesel)
Engine 1V, KKK K24, 2.5" DP, 2.5" Exhaust, GTD intercooler, GTD Nozzles, GTD pump ,10mm Plunger, 30Psi boost, AAZ head gasket, Head P&P, 12.9 grade head bolts
Reply #1June 23, 2010, 11:32:50 am
Re: White Smoke/ Very High EGT's
« Reply #1 on: June 23, 2010, 11:32:50 am »
Is the probe pre or post turbo?
Reply #2June 23, 2010, 11:33:58 am
GTD_MK2
  • 21
    Smoke...
« Reply #2 on: June 23, 2010, 11:33:58 am »
Oh ,i forgot ;)
Its a pre turbo egt.
The smoke under WOT is something like a mix out of white/grey and Black... and smells like unburnt diesel ...
« Last Edit: June 23, 2010, 11:37:23 am by GTD_MK2 »
Reply #3June 23, 2010, 12:13:27 pm
« Reply #3 on: June 23, 2010, 12:13:27 pm »
How many mm of advance are you running?
Reply #4June 23, 2010, 01:22:38 pm
TDsamurai
  • 130
« Reply #4 on: June 23, 2010, 01:22:38 pm »
From my understanding 25psi is well out of its efficiency range, so therefore it will run hot. If you are already getting EGT's into 1750F why would you try and turn the fuel up? What do you have for exhaust? If i were to guess with the limited information you have given i would say its a combination of, too much fuel, too much restriction in the exhaust, and fuel timing is out. Since you dont need the cold start to start it i would say you are too advanced. And with that high of boost pressure an intercooler or water meth wouldnt hurt.
Reply #5June 23, 2010, 01:27:11 pm
« Reply #5 on: June 23, 2010, 01:27:11 pm »
last time i saw a car with mysterious white smoke it ended up being a blown motor with burnt pistons and many other problems
Reply #6June 23, 2010, 06:16:00 pm
GTD_MK2
  • 21
    Smoke...
« Reply #6 on: June 23, 2010, 06:16:00 pm »
I cant say how many mm timing i run , because my dial indicator adapter doesn't fit into the 10mm Head that i fitted into the pump...
The pump mods are : 10mm head, Governor main spring shimmed completely, timing advance piston shaved to get more advance.
So i have timed it by ear and warm start cranking time for the moment...
If i retard the timing i have to crank it 5 to 7 seconds to get a warm start.
But i dont think that the timing is the problem, because i tried it with 2 other pumps that were completely stock except a gov mod, and tried timings of  0.95, 1.0 and 1.05 but that only changed the warm start cranking time, not the high egts or the white smoke...
Downpipe is 2.25", exhaust is 2.5" .
Intercooler is a Stock 80HP GTD unit.
I just upped the fuel to see if its too low to get more boost.
Before the k24 i had a k14 on it with the wastegate disabled, and had the same egts (at this time i thougt the egts are made by the restriction of the way too small turbo)
Another thing that i mess about is that it  now only runs 160kph, 2 months before it used to run almost 200kph.
the engine has 270k miles on it and got some blow by (Oil filler cap dances a bit but doesnt fall down when i open it and lay it on its hole )
Reply #7June 23, 2010, 06:42:07 pm
« Reply #7 on: June 23, 2010, 06:42:07 pm »
Have you tried advancing it?
Reply #8June 23, 2010, 08:12:00 pm
GTD_MK2
  • 21
    Smoke...
« Reply #8 on: June 23, 2010, 08:12:00 pm »
Yes i already tried advancing it , but a little more advance and its going to make lots of noise (clatter/marbles), and still gives the white smoke. so now i timed it to the point it makes good warm starts (about 2-3 turns) wich is short before its going to clatter too much.
Reply #9June 23, 2010, 11:48:34 pm
« Reply #9 on: June 23, 2010, 11:48:34 pm »
Any chance you have some gas in fuel?
Reply #10June 24, 2010, 05:45:00 am
GTD_MK2
  • 21
    Smoke...
« Reply #10 on: June 24, 2010, 05:45:00 am »
No, there cant be any gas in the fuel, thats for sure.
Fuel filter is new.
But now, as you said gas in fuel, which color of smoke makes bio diesel/RME ?
Because here in germany the normal Diesel can contain up to 7% biodiesel....
Reply #11June 24, 2010, 11:30:25 am
  • 3468
    • McScrubbins Body Wash
« Reply #11 on: June 24, 2010, 11:30:25 am »
Check the cam to flywheel timing marks.
You may  find they are out just a touch.
Reply #12June 24, 2010, 07:51:34 pm
GTD_MK2
  • 21
    Smoke...
« Reply #12 on: June 24, 2010, 07:51:34 pm »
Thanks for your help so far...
I've got no air in the IP, and the other pumps , the one i ran for about 2 weeks (about 400-500km) and the other for 4 days, and both showed no air bubbles in the return line.
Injectors are brand new GTD Nozzles (DN0SD274) in the 1.6 single stage injectors.
The Problems i have were the same , no matter wich pump tried.
I've also did a small test drive with timing advanced to very much clatter, but the problems are still the same...
Compression, that could be a factor, i can't say exactly how much it has, but with the right IP timing it starts real good, hot and cold.
Cam timing could also be a problem , because i fitted a lightened gasser 210mm flywheel, and i had the feeling the TDC mark is not exact now...
I think i will check the TDC mark on the flywheel and re-time the engine.
BTW, is the cam timing really so sensible that it cause those problems, when it's for example 1mm out on the flywheel?
Reply #13June 25, 2010, 12:23:44 pm
clarkrep
  • 117
« Reply #13 on: June 25, 2010, 12:23:44 pm »
I'm not the best with math but here are my calculations.
If the flywheel measures 10"(254mm) and I'm not sure what the diameter actually is since I don't have one infront of me, but you can measure it and plug in the numbers.
Circumference=pi•diameter 3.14X10=31.416
Now we need to find how far one degree is at 10 inches 31.416/360=.0873"
Converted to mm .0873/25.4=2.217mm
So 1 mm is about 1/2 a degree at the pointer? And the cam turns half as fast as the crankshaft so it's about a 1/4 of a degree? Doesn't seem right but maybe it'll get a discussion going...
I do recommend resetting your tdc mark though, google the "dropped valve" method of finding tdc.
Hope this helps, good luck!
Aaron
'79 Rabbit Diesel L 1.5
'83 Rabbit GTI 1.6TD
Reply #14June 25, 2010, 07:34:40 pm
GTD_MK2
  • 21
    Smoke...
« Reply #14 on: June 25, 2010, 07:34:40 pm »
I had no time for doing this today, but i think tomorrow i will do it.
Thanks for your calculation ;)
I also did these , but im not sure about how much problems something like a half degree can cause...
But i think if it would be not such a sensible thing, wich other reason should be there for the adjustable sprocket from factory.
Because gassers do not have this, it's a diesel only thing...
So i will give it a try and will do it as exact as i can, then i will know for sure where my timing is set.
The dropped valve method seems to be the easiest way to do this...
