» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Retorquing Cyl Head
Observations: NA pump vs TD pump with a vnt15.
I've noticed a few things here lately.
85? mech TD into a 92 hyd na
Less power after retorque
1.7 headgasket on a 1.6?
1.9td vs 1.9d head and oil squirters on d block
Oil feed line fitting size's
1.6 NA ???? About AC
intake manifold for a gtd
Fuel Preheater theory and application
Trans q's
Eco diesel pump ??? Or a TD w/o the LDA ?
noob 1st post--hello!
Long Cranking New Engine
intermediate shaft bearings
Diesel Pinging?
85 1.6 td, wrist pin bearings, WHERE to buy them?
Ordered Giles injectors
Head Studs: Who's running them and which ones?
Caveat Emptor Turbos
Motor Mount Question
keep blowing exhaust manifold gaskets
IC size???
My new Golf GTD - jingling noise
AAZ wiring and sender Q's
SLOW START<LONG CRANKING TIMES
Bildon oil pan
Lightweight Lifters
Help on a new car
stretch bolts
mech Vs hydro motors?
New to the 1.6TD
Electrical Gremlin
1.5 connecting rod length
AAAAARRGh! seized!
idi diesel to idi diesel......can it be done!!!
Pre-cup cracks
defective pump or fixable?
RPM limit versus powerband increase tradeoff
AAZ oil cooler
fuel filter placement
Where's your redline?
Putting a mk2 cluster in a mk1
TD trans ID ??
My IP Rebuild
1.9AAZ intake manifold alloy elbow wont budge...
1.5 compression numbers
Deck crack near head bolt hole
