Author Topic: 1.9td vs 1.9d head and oil squirters on d block  (Read 6387 times)
March 14, 2009, 05:12:15 am
carrizog60
  • 978
« on: March 14, 2009, 05:12:15 am »
hello
just passed at a friends house todayand talk about 1.9 swap and then...he said"score a D head as it have larger valves on it!"
how he knows?he had a 1.9D seat ibiza that damaged the head and when he pulled it he compared it with a aaz head and the valves were 2/3mm larger...
as anyone checked this?
also,does anyone knows if a 1.6D JK mech engine block as oil squirters?
herad some gyuis talking that some D engines also received them...
Portugal
Reply #1March 14, 2009, 05:50:10 am
gigaz2
  • 626
« Reply #1 on: March 14, 2009, 05:50:10 am »
firing Etka up, will post results in a sec
Reply #2March 14, 2009, 05:58:17 am
gigaz2
  • 626
« Reply #2 on: March 14, 2009, 05:58:17 am »
etka tells me that the valves are different between aey,1y and aaz, all from Seat ibiza 1998.
now to get the diameters:
INTAKE:
SDI
AEY:    028 109 601 G  - 7mm stem (sweet)
AEY:    028 109 601  J  - 8mm stem
1.9NA
1Y:    028 109 601 B  - 7mm stem (sweet)
1Y:    069 109 601 F   - 8mm stem
1.9TD
AAZ:  069 109 601 H  - 7mm stem (sweet)
AAZ:  028 109 601 C  - 8mm stem
Reply #3March 14, 2009, 07:45:40 am
  • 1739
« Reply #3 on: March 14, 2009, 07:45:40 am »
Does it have a spec for an ADG industrial ? I know it's basically a 1Y but it be good to know if it's any different. I didn't think to check while i had the head off.
Reply #4March 14, 2009, 09:42:23 am
ryanp
  • 269
« Reply #4 on: March 14, 2009, 09:42:23 am »
I would imagine the valves would be bigger to get a bit of flow/power due to the lack of blower.
the 1.9D's seem a good engine for a cheap smoker with a turbo and TD pump, Would this work? use a 1.6TD/GTD sump i imagine for the oil return!
I might do this for a budget IDI project!
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #5March 14, 2009, 01:08:22 pm
gigaz2
  • 626
« Reply #5 on: March 14, 2009, 01:08:22 pm »
I didn't get to check the diameter of the valves, I have a catalog somewhere.
I'll check monday
Reply #6March 14, 2009, 02:01:45 pm
subsonic
  • 1836
« Reply #6 on: March 14, 2009, 02:01:45 pm »
Quote from: "ryanp"
I would imagine the valves would be biffer to get a bit of flow/power due to the lack of blower.
Ryan
You can run a 1.9 head on a 1.6 block for better flow, lower compression and higher boost.  Thats what I am in the process of building.  Now all I need is for you to sell me on the cheap that long runner sdi D-port intake you have for sale on tdiclub so I can hook a mechanically controlled gt1749vb to it :twisted:
Reply #7March 14, 2009, 03:24:58 pm
ryanp
  • 269
« Reply #7 on: March 14, 2009, 03:24:58 pm »
Pm me a reasonable offer and i cant refuse! i could get another few of those long runner intakes cheap! if you want a few to sell on to pay for yours everyone's a winner!
I've got a beauty GT18v which would definatly go better than a 17 all day  :wink:
I'd go for a VNT but Im inpatient and dont like trial and error with making the linkage work but i'd like to see your method.
How do the 1.6 bottom ends and 1.9d heads fit?
Ry
Reply #8March 14, 2009, 08:18:20 pm
subsonic
  • 1836
« Reply #8 on: March 14, 2009, 08:18:20 pm »
A 1.9 aaz head will directly bolt onto a 1.6 hydraulic TD block with out modification needed.  You can "improve" the 1.6 block by drilling the steam passage holes that are present on the aaz head but not on the 1.6 block.  A metal 1.9td head gasket is then used.   You now have a head that offers better flow.  It has the D-shaped intake ports.  Compression has been lowered allowing for additional boost.  It is a win win situation.  You can choose to run either the standard 1.6td injectors or the 1.9td dual stage injectors, depending on what set of injection lines you have on hand.  With the correct additional modifications, you should be able to run 150hp no problem.  If you are serious, you are looking into the 200hp range.  It's all old school diesel hot rodding, fuel- boost-intakes and exhausts.
There are a few members on this forum who have been running mechanically actuated vnt turbo's for a while.  There are some very good write-ups on the process.
I see that you get your hands on some nice items over there.  I would gather to say that you will have better luck with selling items over on this forum as opposed to the tdiclub.  The guys over there sure seem to have lots of money, but some appear to be more interested in chip tuning and having others work on thier cars.  On this forum, you have more members who are driving older cars, working on older engines, and turning wrenches themselves. Power on this forum is made with mechanical improvements.
I am currently interested in the intake manifold design.  turboj is currently building a fantastic 1.6/1.9 engine with a nifty dual plenum intake manifold.  Balancing the intake charge is key to keeping the 1.6 together when you start to get into heavy boost and power. His is off a 1.9na 1Y.   I would like to talk with turboj and aki-something about the manifolds they are building.  The long runner sdi looks very similar to the one he is using. What is it off of?
It would be very interesting if there were larger valves available for the 1.9td head.  You might be able to swap in the intake valve which would really help, but I do not know if a non-turbo exhaust valve would hold up in a high performance turbo application.
Drop me a pm ryan about your parts etc.  Dont want to thread jack this any more than I have allready :wink:
Glad ya came over.
Reply #9March 14, 2009, 09:36:47 pm
subsonic
  • 1836
« Reply #9 on: March 14, 2009, 09:36:47 pm »
Quote from: "gigaz2"
INTAKE:
SDI
1.9NA
1.9TD
You should be able to get that information from this link:
http://www.ms-motor-service.com/content_kataloge.asp?area=hauptmenue&site=katalog&cls=02&changelang=02&KatID=193
Reply #10March 15, 2009, 01:13:37 am
MJF
  • 581
« Reply #10 on: March 15, 2009, 01:13:37 am »
1,9 intake valve is 2mm larger than 1,6 intake valve. Exhaust valves are same. Dimensions can be found from Mahle catalog.
No oil squirters in 1,6 na.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #11March 15, 2009, 02:39:20 am
carrizog60
  • 978
« Reply #11 on: March 15, 2009, 02:39:20 am »
i was refereing to 1.9d having valves bigger than the 1.9td
does the 1.9 d block is the same as 1.9td?oil squirters and block strenght?
and valves material?
Portugal
Reply #12March 15, 2009, 02:46:33 am
MJF
  • 581
« Reply #12 on: March 15, 2009, 02:46:33 am »
1,9td and na has same size valves as you can find from Mahle catalog too. Block is same, both have squirters.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #13March 15, 2009, 09:19:21 am
ryanp
  • 269
« Reply #13 on: March 15, 2009, 09:19:21 am »
so a 1.9d would be a good base for a TD? saves looking for an old aaz i suppose!
