» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
HEAD STUD HELP
gunning throttle- clutch slips
1988 1.6TD KKK24 - Low On Overall Power
break in oil questions
Intermediate Shaft Flange is it needed
85 Golf races very high RPMS right after starting even with foot off accelerator
How long does your oil pressure light stay on?
Power Steering Flush Procedure???
Looking for front struts for 92 Jetta 1.6 TD
Peugeot XUD9TE pump
Rabbit Glow Plug Fuse availability?
Rebuild 1.6td on a budget
VE 37 timing advance
1Y IP problem
Parts Value?
diesel vs gas radiator
sticking wastegate on K14 and K24
Wonky performance after head switch
Oil pressure problems
Fitting a t3 or k24 to an aaz, oil return line?
Snapped alternator adjusting bolt
Mk2 1.6 alternator belt change
pistons
Block Price Feeler
Bosch Injection Pump "Cleaning"
Low Performance Turbo Selection
Giles injection pump- how good are they?
Can't Find the SEARCH Function????
Cold start coolant smell?
MK2 5 speed in MK1
AAZ 1.9 TD Weird sound after timing belt removal
Use of a Volvo 740 glow plug relay for Volkswagen engine applications (long).
What is your best timing for winter starting and operation? :)
Injector pump value?
AAZ Head on 1.6 block
mk2 transmission sound?
Odd Intake Noise
Hi 83 Rabbit
Turbo selection for 200+ HP 1.5L IDI
400k mile '92 ECOdiesel gets a K24
TDI transmission in my aaz
IP prime / bottle feed procedures
Looking for a 1.9d 1z Mk3 Jetta/Vento
Overheating again... Blah
Kerosene or Jet A???
VW IDI Marine engine
Why does my glow-plug relay go nuts after a warm engine restart?
throwout bearing plug dia. for mk2 tranny?
Using a gas cluster for use of the Tach
long cranktime on 1.6td
