Author Topic: Why does my glow-plug relay go nuts after a warm engine restart?  (Read 2543 times)
October 26, 2014, 10:42:31 am
sparkoid
  • 37
I replaced the glow plugs and relay awhile back on my 1.6na.  Ever since, when I drive to the store, pick up my cold beverages and then re-start the truck for the ride home, my glow plug relay clicks like a banshee for the ride home.  The ride to the store was long enough for the temp gauge to find it's mid-point sweet spot, and on re-start, the glow-plug "wait" light on the dash does not come on, all of which I presume means the engine is sufficiently "warmed up".
This originally on my 1.6na which is now a door-stop; the 1Y I just replaced it with does the same damn thing...
Any ideas out there?
Reply #1October 26, 2014, 12:23:16 pm
Re: Why does my glow-plug relay go nuts after a warm engine restart?
« Reply #1 on: October 26, 2014, 12:23:16 pm »
Ground Wire, it is loose, broken, frayed or otherwise intermittently going out on you.
Reply #2October 28, 2014, 12:09:57 pm
  • 2931
« Reply #2 on: October 28, 2014, 12:09:57 pm »
Or the seperate wire on the battery post might be loose.
What kind of car?
Reply #3October 29, 2014, 08:53:36 pm
sparkoid
  • 37
« Reply #3 on: October 29, 2014, 08:53:36 pm »
It's an '81 diesel pickup.  The windshield leaks of course, so the fuse / relay panel has been drenched more than once.  Anyone have any ideas / tricks on how to recondition these things?  And the terminal lugs on the harness that hooks up to them?
Reply #4November 06, 2014, 12:33:21 pm
  • 2931
« Reply #4 on: November 06, 2014, 12:33:21 pm »
Then the ground connection is behind the fuse box. Screwed to the firewall.
Reply #5November 06, 2014, 01:55:32 pm
air-cooled or diesel
« Reply #5 on: November 06, 2014, 01:55:32 pm »
perhaps you can try to use a silicone trim/gasket sealant to seal the windshield for a while, you got to stop your electronics from getting wet; your floor too; rust, you may need to junglegym under there and get a good look at all contacts; you dont want to end up having to replace the relay box, or fuse box either, relays are expensive enough.
