» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
setting throttle shaft
More fuel faster....
1.6 Turbo pump on 1.6 N/A engine???
AAZ head gasket on engine code CY?
1.6 TDC and camshaft timing???
Downpipe nuts...copper?
coolant fan runs all the time after radiator change
Using gasser exhaust with diesel
passenger side engine mount Mk1 Rabbit
Gearing: how tall is too tall?
Compound pics
Glow Plug Question
RADIATOR SOURCE????????
Rabbit Diesel Motor in Diesel Vanagon need advice.
A couple of questions considering 1.6GTD engine
Crank gear bolt - how much torque?
Bad Injector Seat - Help!
Some questions....t25 / custom pump
Difference between 81 and 82 non turbo 1.6 ??
30-32 psi goal
upper radiator hose
821.6 freeze plugs, who has them?
mk3 Jetta GT to GTD conversion (and pre-conv rebuild)
bearing girdles
no start...
where to find a dial indicator adapter for an 8mm shank
Turbo Diesel Cold Start
Mk3 Gasser to Diesel swap
Mileage Question.
IP shaft play: how bad is bad?
anyone tried these timing tools?
China made parts
New Turbo Exhaust manifold ! & Long Runner Intake Assy .
Compression limits? AAZ
waste gate on 1990 jetta
Pump timing - on the bench?
Reseal throttle shaft on IP ??
T2 TO T3 ADAPTER ( EXHAUST ) MANIFOLD
F*@£&%$ starters!!!!
vnt best known available?
Excessive fuel consumption
another pump mod // stage 4
Return line size question
1.6L piston numbers
source for 293 or gtd injector tips
rebuilt head, precup protrusion specs?
proper oil pressure, 1.6 n/a, mechanical lifter head
Would too much fluid...
Tell me what you think of this smoke.
lookie what i got...
