View full version: IDI Engine
  1. What is this pump?For 1.6TD or 1.9TD!?!?!?
  2. Minimum oil quantity
  3. Noisy lifter! was "Got Problems! Lost a prechamber inse
  4. Still Looking for a Guage Cluster with tach
  5. rabbit eng; remove w/ tranny, or separately??
  6. Consensus on 1.9TD v. 1.6TD??
  7. Crank pulley problem-need help
  8. "Blueprinting" defined
  9. TD radiator fan wiring
  10. Vanagon Trouble
  11. Mk1 Glow Plug ......
  12. Modding my IDI
  13. Low oil pressure/vacuum pump questions
  14. DIY turbo rebuild?
  15. Advice and next steps?
  16. Differences with pumps and turbos from 86-92?
  17. Downside of Reusing Stretch Bolts
  18. Does my ECOdiesel have a LDA?
  19. Smoking AAZ
  20. Special tool source?
  21. need a cylinder head rebuilder in Toronto
  22. will this compression tester work?
  23. Stupid Turbo Problem
  24. GTD injector nozzles
  25. Cluster
  26. Clicking
  27. AAZ Crank Pully on Recently Manufactured Motors?
  28. engine swap question
  29. Turbo upgrade options for 2.0 TD
  30. adding v pully to surp belt
  31. Timing a non-turbo 2.4 (VW engine ina Volvo)
  32. Rear main seal leaking, causes
  33. Tuning 1.9td
  34. What Oil Spec for a AAZ?
  35. Converting to Serp. belt?
  36. Battery relocation to boot (trunk)
  37. injector nozzles
  38. Skirt sprayer removal.
  39. Quick Head Port & Polish Question
  40. Quick question about 1.9L TD crank sprocket / pully problem
  41. Fuel Quantity vs. Heat
  42. My new FMIC (91 SB engined GTD A2)
  43. question on turbo diesel 1.6
  44. turboing an N/A motor?
  45. 1.6TD Valve Cover Breather
  46. experience needed on pump settings
  47. Fantasy 1.6 TD - Fresh build, what parts to use.
  48. TD Injection Pump Advice
  49. inline Diesel filter
  50. 1.9 TD max horsepower?
