Author Topic: inline Diesel filter  (Read 2628 times)
February 22, 2005, 03:28:15 pm
sethyboy85
  • 284
« on: February 22, 2005, 03:28:15 pm »
I need to find a inline diesel filter, I have had it with the factory one.
any make or model it doesn't matter to me, just as long as I can go to a parts store and get one. inlet outlet diameter does not matter.
thanks
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #1June 27, 2005, 10:08:25 am
JimK
  • 8
Re: inline Diesel filter
« Reply #1 on: June 27, 2005, 10:08:25 am »
Quote from: "sethyboy85"
thanks
I use a filter that comes on my 4020 JD tractor and other equiment. It is glass and has a metal base and seals with o rings. It has a drain for water and you can see the water in it if you have that problem. I dont have the part number, but I can get it. It is used on a lot of different equiment. A JD air ( diesel aircompressor) and others. I had a double block that I used on a dodge diesel truck. Good luck JimK
Reply #2June 27, 2005, 06:34:16 pm
srivett
  • 318
« Reply #2 on: June 27, 2005, 06:34:16 pm »
I found a filter plate and filter in the back of an old Jetta at the wrecker.  I think it's a Rabbit part.  Anyway, it only cost me 10 bucks and it's just like an oil filter with a drain on the bottom.  JackBombay has a picture of one in his Quantum repair.
Steve
1992 1.6D Golf - 412K km
