Author Topic: turboing an N/A motor?  (Read 4747 times)
June 26, 2005, 10:59:48 pm
iggi
  • 33
« on: June 26, 2005, 10:59:48 pm »
hey everybody,
In my quest for a diesel I've come across a '89 Golf  that I'm pretty sure was originally a N/A motor that's been converted to turbo.
Is this a good idea or a bad idea?
Am I better off waiting for a factory built turbo car, or is making your own an ok way to go?
Thanks!
'97 Jetta GL TD
'87 Vanagon Westy
Reply #1June 27, 2005, 12:21:27 am
web
  • 56
« Reply #1 on: June 27, 2005, 12:21:27 am »
Pretty much depends on how (well) it was done...
If they dropped in a whole engine + gearbox, not much can go wrong, really.
Current car: '92 Fiat Croma TDID, similar to VW TDI only completely mechanical DI - with VE-style pump.
Previous car: '84 mk2 diesel, w/1.6TD swap ('86 hyd engine), 9mm plunger, KKK K24.
Reply #2June 27, 2005, 12:46:20 am
iggi
  • 33
« Reply #2 on: June 27, 2005, 12:46:20 am »
uh no..
N/A block, head and tranny.  They installed turbo and stuff from a wrecked TD.  Not sure yet if they replaced the IP.
'97 Jetta GL TD
'87 Vanagon Westy
Reply #3June 27, 2005, 08:24:50 am
Northboundtrain
  • 131
    • http://boulderbiodiesel.com
« Reply #3 on: June 27, 2005, 08:24:50 am »
N/A engines do not have oil squirters or turbo pistons.  I'm not the expert and have no direct experience with this, but the consensus on this forum is that the n/a engine cannot deal very well with the extra heat generated by turbo charging.
'75 Chevy 3/4 ton 6.5L conversion
'91 Jetta 1.6L NA
Biodiesel
"The fool who persists in his folly will become wise." -Blake
Reply #4June 27, 2005, 11:07:40 am
iggi
  • 33
« Reply #4 on: June 27, 2005, 11:07:40 am »
Thanks for the feedback.  That's what I suspected but wasn't sure.
'97 Jetta GL TD
'87 Vanagon Westy
Reply #5June 27, 2005, 07:13:26 pm
fspGTD
  • 1529
« Reply #5 on: June 27, 2005, 07:13:26 pm »
IMO, turbochargers are great things to have on a diesel.  Whether there are piston squirters or not, turbochargers properly set up work very well on these IDI Diesels.
The TD block, with its piston-cooling oil jets, will be able to safely run more combustion chamber temperature than a non-TD block with all other factors held equal.  This is particularly important with a small restrictive turbo and exhaust, and/or without an intercooler.
With unrestrictive turbo and efficient intercooler, I find it hard to see a need for piston cooling oil jets.  With factory 1.6lTD turbo and >80% efficient intercooler, I find that EGTs are several hundreds of degrees below factory 1.6lTD temperatures even with fueling levels far beyond the smoke limit.
Jake Russell
Reply #6June 27, 2005, 09:33:29 pm
« Reply #6 on: June 27, 2005, 09:33:29 pm »
it would be nice to have water injection for non TD blocks though.   Inject the water on the exhaust stroke as the valve is being opened.  The extra steam would help boost as well as cool the piston :D
one tough setup though :(
Reply #7June 28, 2005, 05:19:30 am
Justin
  • 455
« Reply #7 on: June 28, 2005, 05:19:30 am »
when i get around to rebuilding a NA 1.6 i plan on adding oil squirters coming either from the main bearing oil gallies or on the connecting rods (being drilled into the connecting rods pointing to the piston and feeding from the rod journal)
and then i will be adding a turbo charger, i will need to aquire a LDA device for my injection pump
i now it has been done and i figure why not
later
justin
www.archeryprostaffmi.com
Reply #8June 29, 2005, 07:59:44 pm
chrissev
  • 694
« Reply #8 on: June 29, 2005, 07:59:44 pm »
Quote from: "iggi"
uh no..
If they didn't replace the IP then you have an eco diesel.  All the turbo will do is pressurize the intake, and there will be minimal if any extra power created.  I can't see it causing any problems.  You will have  a very efficient engine that will probably get quite a bit over 50mpg consistently.  With the turbo pump you are supposed to get less mpg but if that is true then the non turbos must be wickedly fuel efficient because I can get 52mpg out of my 1.6 turbo diesel.
As far as extra stress on the engine is being talked about, most people talk about the oil squirters under the pistons which cool the pistons.  The turbo increases the amount of air in the cylinders, to which more fuel is added, creating a bigger bang and more downward force on the piston, and also more heat.  I guess you could also cool the pistons from above through intercooled air coming in the intake.  Intercooled air is heavier though (more air molecules) so perhaps that would make more heat from increased amounts of air being compressed.  It is an interesting idea.
My experience with VW is they generally don't do anything unless they have to, so running a turbo with a turbo pump on an N/A engine is definately experimental.  Personally I wouldn't do it except with an old beater engine that I didn't care about.  Definately would not do it on a fresh rebuilt N/A engine.
Reply #9June 30, 2005, 02:12:03 pm
Patrick
  • 1034
« Reply #9 on: June 30, 2005, 02:12:03 pm »
