View full version: IDI Engine
  1. Oil pan baffle
  2. Help with AAZ pump wires please
  3. Where to mount gauge
  4. 1.9 AAZ Crank Bolt over torque
  5. 1.8 CAMSHAFT
  6. THREAD SIZE OIL FITTING AAZ , RETURN banjo bolt ON THE BLOCK
  7. lifted the head...now what?
  8. Diesel Head Gasket Replacement, what kind of head bolts?
  9. oversized valves
  10. Free intercooler......too big??
  11. Taller 5th gear, where to get one
  12. turbo identification
  13. Part Number for Bushings
  14. Extra smoke at high RPM's
  15. AAZ injetors
  16. AAZ quit on Gas
  17. Open wrench for injectors
  18. Odd issue with an AAZ
  19. Downpipe Question and Issues
  20. 1.9td idle
  21. Why Can't I Read English?
  22. DI camplate on IDI engine
  23. VNT Control Pictures Thread....
  24. AAZ Crank Nose
  25. mk3 1.9td what to look for?
  26. water temp sender install on AAZ
  27. A thing about batteries I experienced
  28. Just a power question
  29. Where to buy EGT guage kit
  30. Injection Pump modification basics for 1.6 NA
  31. alternator
  32. simple question...
  33. New starting problem
  34. Won't stay started
  35. Camshaft
  36. Diesel fuel line
  37. New to the board.
  38. motor tranny swap
  39. Radiator cap pressure?
  40. What PSI of Boost
  41. AAZ drive shafts
  42. SVO coolant system not circulating! Help!
  43. 1.9 AAZ and 1.6 diesel cams.
  44. White Smoke !!
  45. Flywheel advice
  46. May i pose an intake location question?
  47. EGT Gauge needed??
  48. our site has been flagged as "Malicious sites" by SmartFilter
  49. Injector/ Nozzle Numbers
  50. My 81 Rabbit Diesel project
