Author Topic: AAZ injetors  (Read 2401 times)
October 02, 2009, 06:59:21 pm
jbturgeon
  • 71
AAZ injetors
« on: October 02, 2009, 06:59:21 pm »
Hi guys, i am about to take off my injectors with a visegrip and was wondering, before i make a mess, what size of socket will fit to take those out properly.
Thx very much
AAZ for life!
Subaru Loyale 4x4
Reply #1October 02, 2009, 07:01:32 pm
truckinwagen
  • 1895
Re: AAZ injetors
« Reply #1 on: October 02, 2009, 07:01:32 pm »
its a VERY DEEP 27mm I think.
I have, when the socket was unavailable and I needed to get the injectors out pronto, used a big crescent with success.
I would heavily advise against using vice grips.
-Owen
83 Opel Kadett Diesel
Reply #2October 02, 2009, 07:12:29 pm
macka
  • 957
Re: AAZ injetors
« Reply #2 on: October 02, 2009, 07:12:29 pm »
you could also use a 27mm open end wrench
Quote from: Vincent Walden
Reply #3October 02, 2009, 07:16:20 pm
truckinwagen
  • 1895
Re: AAZ injetors
« Reply #3 on: October 02, 2009, 07:16:20 pm »
true, but who has one of those?
if you are going to buy a wrench for the injectors, you might as well get a socket so you can use a torque wrench for installing them again.
Reply #4October 02, 2009, 07:21:22 pm
jbturgeon
  • 71
Re: AAZ injetors
« Reply #4 on: October 02, 2009, 07:21:22 pm »
I already try a 27 impact but too short..
Will try to exchange it tomorow
Thx for the replies
AAZ for life!
Subaru Loyale 4x4
Reply #5October 02, 2009, 07:23:00 pm
truckinwagen
  • 1895
Re: AAZ injetors
« Reply #5 on: October 02, 2009, 07:23:00 pm »
it may be hard to find a socket deep enough, many people have purchased a cheap socket, cut it in half and welded a piece of pipe in to make an extra deep socket.
if you can find a really deep one though, that is the best option.
-Owen
Reply #6October 03, 2009, 01:13:23 pm
Syncroincity
  • 727
Re: AAZ injetors
« Reply #6 on: October 03, 2009, 01:13:23 pm »
SEARS... Their 27mm deep 1/2" drive fits nicely. You have to experiment a little with it, for some reason it fits better in one position, where it does not interfere with the fuel return nipples.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #7October 04, 2009, 07:23:13 pm
neimis
  • 75
Re: AAZ injetors
« Reply #7 on: October 04, 2009, 07:23:13 pm »
It is extremely difficult to find a socket with enough deep clearance inside to fit over the 2 stage injectors. The sockets at Sears (here in Vancouver, anyway) are now just the same old cheap stuff you find anywhere else, don't work.
I finally found one that works - it is a Wright tools 1 and 1/16" deep socket (fits 27 mm perfectly), the flutes run all the way to the bottom of the socket and will fit over the long injectors. I got it at The Tool Place in Kamloops. Try finding somewhere that carries Wright tools, the model stamped on the side is #4634, maybe that will help you find one, good luck.
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
