EGT Gauge needed??
Topic: EGT Gauge needed?? (Read 2286 times)
September 23, 2009, 08:27:18 pm
dieselsmoke
EGT Gauge needed??
September 23, 2009, 08:27:18 pm »
I will be running a 1.9 AAZ with a k14 turbo and a giles performance pump which he will set so that it will work with 15 psi of boost. Do i need an EGT gauge or should I been fine. i am not turning the boost up more that that.
September 23, 2009, 08:30:24 pm
Re: EGT Gauge needed??
September 23, 2009, 08:30:24 pm »
I have a similar setup and can get into the redzone with 15 psi under certain conditions... so I'm glad I have an EGT gauge.
September 23, 2009, 08:39:27 pm
dieselsmoke
September 23, 2009, 08:39:27 pm »
what egt setup are you using??
September 23, 2009, 09:34:14 pm
September 23, 2009, 09:34:14 pm »
Aircraft Spruce thermocouple as per the FAQ, IssPro gauge.
September 24, 2009, 08:44:34 am
4wheeler
September 24, 2009, 08:44:34 am »
I have a K03 now, Would like to be able to find a K14.
With the KO3 I`m always pushing the EGT limits.
Of course I put my AAZ in a sidkick which weights in at 3200lbs
September 25, 2009, 06:08:39 pm
Rabbit TD
September 25, 2009, 06:08:39 pm »
Everybody should have an EGT gauge to know what's going on inside. If you're watching a boost gauge you should have the EGT right beside it. Little changes can make a big difference if only in temp. itself and nothing else.
EGT Gauge needed??
