Author Topic: THREAD SIZE OIL FITTING AAZ , RETURN banjo bolt ON THE BLOCK  (Read 2102 times)
October 06, 2009, 02:09:10 pm
GEE-BEE
  • 1604
« on: October 06, 2009, 02:09:10 pm »
Iam not sure is iam going with a 45 or 90 degree an fitting, I did purchase a kit for the turbo fitting and i will need a fitting adapter for the BLOCK , Iam going to make a teflon hose assy ( crimp fittings ) an on both end's -8 dash (1 /2) I.D.
Question ?
Thread type on the Block ?
Thanx
Gee-Bee
« Last Edit: October 06, 2009, 02:25:25 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1October 06, 2009, 02:17:56 pm
rallydiesel
  • 1880
Re: THREAD SIZE OIL FITTING AAZ , RETURN banjo bolt ON THE PAN
« Reply #1 on: October 06, 2009, 02:17:56 pm »
I thought AAZ's had the return fitting on the block. The return fitting on a 1.6td oil pan is something weird. After trying to locate an adapter that would fit, I ended up cutting mine off and welding a -8 AN 90 degree fitting onto it.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2October 06, 2009, 02:27:34 pm
GEE-BEE
  • 1604
Re: THREAD SIZE OIL FITTING AAZ , RETURN banjo bolt ON THE BLOCK
« Reply #2 on: October 06, 2009, 02:27:34 pm »
Oop's my bad
You are correct..
I will be using a AEROQUIP Aerospace teflon hose assy with the Intergal firesleeve , 30 % smaller than a rubber s/s braid but with the silicone cover good for 15 minutes at 2500 open flame...
temp range -65 to 550
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
